- 1 Dec 2015
damn ... https://www.hardwareluxx.ru/index.p...-o11d-mini-lancool-ii-mesh-i-lancool-315.html
though personally think they should have ditched ATX support to trim some height off , wouldn't of fitted a 60mm thick rad up top but 45mm would have been plenty!
from looking at it , SFX PSU chamber so 63.5mm Chamber vs 86mm for standard ATX PSU .
Houses a 120mm at the back so using the XL main chamber sizing leaves this roughly 265mm Wide so 10mm slimmer then standard Dynamic and 22.5mm slimmer then XL
Standard Dynamic Height is about 446mm , so knock off the 60mm clearance height in it for thick rads , Plus take away a PCI slot (18mm) as its now 7 vs 8 = rough height of 368mm odd in height
