What PSU you got? My SF750 reached fine on the 24pin. And the PCI-e ones reached OK too, but put 150mm extensions on to tidy the ends.
I have the Same PSU, good to know, I'll just do the extensions, awesome build btw.
Sorry if this has been asked. But, can the brushed aluminium panel on the front of the white case be removed? I'm wondering about spraying it white to match the rest of the case...
Perfect, cheers dudeYes, it can. If you remove the front panel inputs, and the 4 screws on the inside of the roof, the top bit will come off. There are little caps under the screw head that pop off so be careful not to loose them. Once that is off you need to drill out one rivet at the top of the brushed panel, then it slides up on some tabs to remove it. I didn’t bother replacing the rivet as it sits in place fine without it.
Can you tell me if the top panel that needs removing is aluminium or plastic? Case hasn't arrived yet and just want to get an idea of what I'm dealing with. Is it easily snapped or bent? CheersYes, it can. If you remove the front panel inputs, and the 4 screws on the inside of the roof, the top bit will come off. There are little caps under the screw head that pop off so be careful not to loose them. Once that is off you need to drill out one rivet at the top of the brushed panel, then it slides up on some tabs to remove it. I didn’t bother replacing the rivet as it sits in place fine without it.
