Lian Li v350 review *LOTS OF PICS*
Nice review.
May I ask how quiet the fans are? Im looking to build a new silent HTPC and would like to use this case.
Not got the hardware in there yet dude, awaiting cpu... (i too only 'read' the pics ;))
Should have the cpu by the weekend, so i'll get the pics and reviews/conclusion up then. From my other lian li case fans though, they aren't too noisy, but could be quieter, i would have thought the 80mm fan would kick out a bit of noise, but you can replace the fans if need be, they are easily accessable, and it would only take a couple of mins to change them over.
I think this thread has just made my mind up on which mATX case to get. Cheers for the pics! :)
Now just to find somewhere that has it in stock...
Edit: Could someone measure the distance between the motherboard and the underside of the PSU? I want to know if an Arctic Cooling Freezer 7 Pro will fit in there.
I'm about to fit the cpu which arrived today, i'll measure it for you then, but i#m 99% sure that an ac freezer 7 Pro will NOT fit there. You going to need a low profile cooler i'm afraid...
*UPDATE*
Added the answer to your question in the lastest update Dingleberry88, and, completely off topic, who's the chick in (one of) your sigs?
Lastly, Dingleberry88: There was a lot more room than i thought between the mobo and psu, i make it 128mm +/- 2mm, which is getting very VERY close, as ocuk state that the ac7pro is 126.5mm tall... good luck :eek:
Muchos, muchos gracias! Looks like I'll be good to go with my build then. :)
That beautiful lady would be none other than the mesmerising Zooey Deschanel.
Edit: A question about the motherboard you're using; can you run the RAM unlinked?
Edit2: Nevermind, bought one anyway. :)
Sort that mess out! :D
Thought it was the hhg2tg chick... damn straigh she is mesmerising...
there are only 3 devide option on the ram... x2.66 x3.33, x4.00 not so good....
It also looks as though th mobo goes into a continual reset loop if i try and change this...
Trying my hardest to get some benches up, but his board is just not behaving... man i hate giga***** asus ext...
Hard to get an idea of size from the pictures - do you think this could be used as a media PC in a lounge or is it a bit too big?
Installed optical drive, note, the rail where the screws slide down has a slight notch in the end, so it holds the optical drive in place. Others are reporting that they have to use an extra screw to hold it in place, which is a pain, as you need to remove the PSU and/or the HDD's to do this
If you look at the instructions, you'll see it says to use thumb screws where I've put the red circles:
What are instructions? :confused: :p :D
But yeah, turns out i had to, it's held in place pretty well without the thumb screws, but the vibration is crazy when the drive is in full spin...
