Ok guys, so i was wondering if you could all give me some advice
I have a Lian Li XL with
Bottom Rad : 1 X XE (intake lian li 120mm fans on)
Top Rad: 1 X PE (exhaust lian li 120mm fans on)
1 Intake fan at the back of the case (blowing air into top rad)
what would be the most beneficial for the side space of the case:
PE Radiator (Noctua Slim fans) which is my current set up vs 3 full sized intake fans with no rad?
My friend seems to think i should get rid of the side rad and allow for extra airflow to the top rad (he thinks it is being choked of air), i personally think the 3rd rad with the slim fans is more beneficial. Does anyone have any experience with this?
Is it possible that if the top rad is being choked of air, that it is heating up my loop? the XE due to the thickness doesnt allow for much airflow and neither does the side slim fans really, but i do have the fan at the back blowing cool air, and there is atleast still some airflow.
it is worth noting that i did test without the side panel on (to allow for max airflow) and it seemed the tempratures did not change by a noticeable amount.
5800X3D
RTX 4090
EK D5 Pump
5800X3D
RTX 4090
EK D5 Pump
