- 14 Jul 2005
- Birmingham
Having a bit of an annoyance with these OSB loft boards.
First I bought 6 packs from Wickes which were all fine. Then I went back for 6 more packs and of these, 4 packs had a slightly different cut on the T&G profile meaning they didn't sit flush with the original ones. Returned to the store and all new packs for sale have the slightly modified profile so didn't fit properly.
Went to B&Q with my offcuts sample, and their packs (same manufacturer, same packaging), all seemed to fit perfectly so I bought 6 more packs.
However on fitting, 2 of these packs also have a slight variation in T&G profile so not sitting perfectly flush.
Have to go back again today now and see if I can get the packs which match the original ones.
Update - of the packs at B&Q, found 6 more packs that had the right profile, the rest weren't. There's nothing on the packaging (except for one thing, spotted later, will come on to) that indicates a different batch. Barcode is identical, no ID or date marks. Anyway, dug around and moved a load of board packs to get to some at the back - and lo and behold - a whole pallet full of the ones I need.
So clearly there has been something changed at the manufacturer that is meaning a slightly different cut on the T&G. I am not sure whether I have the old version, or the new, but clearly something is different.
Now, what we then spotted was the printed label on the front of the packaging shows an image of a completed loft using these boards. On the one type of pack, the image is a greeny tint, and on the other types of packs, its more of a yellowy tint. Its otherwise exactly the same layout, and image.
Edit - here's the packaging. Spot the difference. Even if I spotted this in store I would assume just printing variation.
