I like decent screws as well, I used a hell of a lot of these and they were great.
Screwfix
https://www.screwfix.com › cat840...
Floor-Tite Flooring Screws
For my loft I doubled up the joists with 47x75 timber so I had 150mm height.
Used 145mm PIR insulation then boarded.
Really took a lot of the flex out of the loft as well and I felt was a step up Vs the loft leg things.
In the far reaches of the loft where I didn't double the joists I used 45mm PIR in between the joists then another layer of 45mm over the whole lot.
Also used lots of expanding foam for any hard to reach bits.
Screwfix
