Logitech Keyboard Dealio
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys!
I have secured a deal on the Logitech G110 Keyboard, enabling OcUK to offer the best price in the UK at under £50. Strickly limited to only 200 units, grab one before they run out!
To celebrate here are a few gif's.
Logitech G110 Illuminated Gaming Keyboard (920-002241) @ £49.99 inc VAT
Ready to step up your game? The Logitech® Gaming Keyboard G110 gives you what you need to customise your setup, communicate more effectively and execute complex commands easily. Locate the correct keys – even in the dark – with backlighting colours you can select and assign. Strategise with teammates and trash-talk enemies using the integrated USB audio. Configure up to 36 single keypresses or complex macros per game on the programmable G-keys. Use the MR key to record new macros on the fly. Connect your gaming mouse or flash drive to the Hi-Speed USB 2.0 hub port. Your game won't be interrupted until you're ready to call it quits, by disabling the Windows Context Menu keys with the game/desktop mode switch.
- Custom Colour backlighting
- Intergrated USB audio with seperate headphone and microphone jacks
- Twelve programmable G-keys with 3 macros per key
- High Speed USB 2.0 Hub built in
- Enable/Disable Windows/Context Menu Buttons with the flick of a switch
- Windows XP / Windows Vista / Windows 7 Compatable
- Removable Palm Rest
- Intelligent Cable Management
- One Touch Media Controls including volume control
- 2 Year Limited Warranty
Was £64.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
don't supose theres any news on when the G19s will show up? ;)
(before anybody says mechanical or gtfo - its for a friend i swear ! ;) )
I can't see it in the picture (and since it's not in the description I'll take this as a no), but does this keyboard still have the screen in the middle top like the older models did? Always wanted a G15 for it but could never justify spending the amount they were at the time.
No, that would be the G510 which replaced the G15.
This is the G110 which replaced the G11.
Yeah, the new "s" range is not available yet either. Logitech ended current range before the new range was released, bit of a boo-boo in my opinion.
Talk me into it ace, what will it do that my arctosa won't? Sell it to me.
The built in headphone jack and usb ports almost has me sold, should make the cables around my desk that bit neater for my headphones and mouse.
Well there is the backlight for evening work. Also the keys on the Arctosa are low height, personally I prefer full height keys. :)
Good price for a good keyboard! I could have got that price off Logitech's VIP store a bit ago. ;)
*hides*
Ah....but which side of the keyboard are they fitted? Reason I ask is I bought my lad the Gigabyte Osmium a week or so back, that has usb and headphones jack plugs.....exiting on the right hand side of keyboard, right where you would have your mouse (right handers anyway)....bit of a design flaw there, he won't use them because of this.
The USB port and mic/audio ports appear to be on the rear of the board so out of the way :)
Just doing some reading up of reviews on this now. I'm itching to buy something :(
The G510 can be had for under £70 elsewhere and it has a screeeeeeen and 6 extra macro keys :D
