Logitech MX Master 4
13 Feb 2008
Glasgow
So what do we really know about this new Logitech MX Master 4?
Why the hell its so heavy? Keycron I think has similar mouse and two times lighter.
I have the Keychron M6 and it is much lighter and similar in shape and design but it feels a lot cheaper too and has a rattly wheel. It's nice though with 1000Hz polling and long batteryy life otherwise but doesn't have the per-app features to customise like Options+ gives you.
MX Master 4 seems a bit of a dumb "upgrade", it has the excat same switches so the primary buttons could go dodgy again like MX Master 3S does (I've had 2 now replaced under warranty), same 125Hz polling rate (wtaf??) and the rubbery coating is now gone replaced with textured plastic with only pure silicone on the finger and thumb rest areas so should last much longer like silicone spatulas do in the kitchen.
Logitech has a trade in which gives you £30 for a MX Master 3S so you could get MX4 for under £100 that way, but I don't think it's a reasonable enough upgrade over the 3S given how very little has changed.
The haptics engine is mostly pointless and probably why it weighs MORE than the already heavy 141g 3S.
I'll happily take the weight for the solid feeling these mice have. My G502X feels and sounds hollow & cheap compared to my Master 2S.
I ageree that the upgrade is a little pointless for 3/3S users, but I'm very keen.
Haptic feedback adds weight, and uses more power so it needs a bigger battery. AND that battery is Lithium Ion now instead of Lithium Polymer in the previous versions. Li-Ion is typically slightly heavier than Li-Po but does give you faster charging.
Edit - Also it's a lot more repairable than previous models. Lots of screws instead of glue and plastic clips. More weight...
I've just ordered one actually as realised my 3S is still under retailer warranty so filed an RMA and they offered a refund. the left and right buttons are dodgy after a year, sometimes have to double press MB2 and sometimes MB1 double clicks.
So £80 being refunded and the MX4 is £119, making the total end cost of MX4 for me £39.
That will be fine.
Holding out ion the faint hope that Amazon does something in the upcoming Prime Day. Unlikely for something so new but it's worth waiting to see.
Copy paste from the buying stuff thread but it arrived today:
So far it's excellent, the quality upgrade doesn't translate in photos but it feels much nicer, no more weird rubber coating and the side grips are proper silicone like a kitchen spatula so very hard wearing it feels like.
The extra 10g weight can't really tell as it's so heavy anyway lol and Options+ asked to copy my custom settings over from the 3S which is rather neat. The actions ring thing is really cool actually, thought it might be a gimmick but it's fully customisable on a per=app basis so is actually useful.
Edit*
My review is up:
That will be fine.
How long was the warranty? Sounds like somewhere I would want to be buying from if they honour a decent warranty (rarity these days).
I'm considering one of these but reading that there's no onboard memory so you have to set the software up on each PC.
I can't see my employer allowing Logitech software unfortunately so possibly rules this one out. Even my headphones have onboard memory, can't understand why Logitech skipped it!
This was with Amazon and warranty was the usual year retailer thing, although Amazon being Amazon, they tend to be fine if it goes over anyway.
You could request the software to see if your workplace will allow it perhaps? It is a Bolt device so is secure enough for business use, maybe play that card to them?
I did today, Resounding No :cry:. I'm not surprised but still disappointing. I think half the features would be negated by not having the software, action wheel thumb button wouldn't do anything etc.
  • Sad
Reactions: mrk
Can be had for £83.99 if you search on a popular UK deals site, it did include a free carry case but they have sold out of those.
Still is for £83.99 for NHS, I get discount codes (25% off on Logitech site).
But I think I'll get myself PRO X SUPERLIGHT 2 DEX.
I actually forgot to check but I found out I get 30% off Logitech stuff through work perks, damn it....
Does anyone know of the real world difference in the the Mac version?
Also is the MX s Keyboard much if an upgrade over the regular MX?
I see the are doing trade in offers for MX Mouse as well..interesting.
Recently went down a rabbit-hole reseacrhing this. Short answer: None.
The Mac version has "For Mac" branding on the underside instead of the Bluetooth and Bolt logos (although it still supports both), has slightly paler-coloured buttons (I think to match Apple colours), and does not come with a Bolt dongle.
Unless you're an UBER-fan of the different colour, the identically-priced Mac version is objectively worse for the money.
Stolen from here:
The MX Keys S has new Customizable Backlighting, Smart Actions to optimize nearly every aspect of your workflow, more Sustainable materials, new color Pale Gray available, used Logi Bolt receiver compare to previous MX Keys that uses Unifying receiver and it has an Emoji-Dictation and Mute/Unmute Keys.
Whether any of that represents an actual upgrade is subjective.
Stolen from here:
Ha...doesnt matter...had a discount code but Logitech dont even deliver to NI BWAHAHAHAH...losers.
WAs buying the Mouse, Keyboard and Console....wow..really did themselves a favour there.
So, in general - how is it?
Is it good for gaming as well? I dont play CS, but games like adventure, strategic etc
I've been using Superlight for 5 years now and worried that if i get MX4, its gonna be too heavy for me.
And why they kept polling rate of 125 Hz???
NObody knows why 125Gz still, but for that kind of gaming it would be fine though it is heavy.
Otherwise it has been fine for normal use and the software adds app specific feature syou can customise that I use a lot. It's much nicer in the hand than MX3.
