Look what I've got (EVE Fans)
OSX Client or Crossover?
Ive been running under Crossover for a while and it runs nicely, just a shame ive lost interest in Eve atm... I suppose a native OSX Client might boost my interest slightly.
kk... I hate you.
Who do I have to pod to get me that client?
Ive got to assume your in the closed Beta, in which case... Arhhhh... you just broke the NDA, im telling on you. Unless ofcourse the Open Beta is now available, but, I cannot see any mention of it on the Eve Forums.
kk... I hate you.
There is a news article, you can download the client nowand connect to Multiplicity
The client is still an .exe?
How do I go about this?
Thanks, and just to think...I canceled my subscription 2 weeks ago because I couldnt be arsed switching to Windows, and have had a long break from it!
That's about to change.
It's a .dmg if you look at the top news item at login, then click readmore, about half way down you'll see a link to the .dmg file
Got it running at the moment, probably looking at about a 20% reduction in FPS on my macbook pro over running eve in bootcamp.
C2D 15" 2.16Gb // 2Gb Ram // x1600 mobility
I was getting about 15 - 25fps depending, in station 30fps + outside station no one else around 25fps fluctuating, then warping to a belt, 15 - 20fps.
That seems kinda low, I'm not really in a position to pass a judgement on that though as I've not played EVE in ages. :o
It is quite noticeably low, on bootcamp it did run a lot smoother, although I cant remember the FPS being much higher, but I may be remembering wrong.
For a first release it seems like a good start, although in the video section it shows as D3D Hal, I assume this is a virtual direct x emulator?
Direct3D HAL (hardware acceleration layer) uses your super-duper 3D video card hardware to speed up shaded mode and realtime rendering on PCs. It is limited by the card memory and the quality of the manufacturer's drivers.
Looks like it.
Fantastic!
But is it me, or is everything 100.00isk?
I bought like 1 Million Raven's and reprocssed them
Equals = I'm Rich?
:p
/Or will my dream end, and they take everything away from me when the test server ends?
