Looking for a 1440p Monitor
14 Nov 2022
Leeds
I currently use a 1080p Iiyama 25.5" (TN LCD) and am considering replacing it with a 1440p monitor. My PCs main uses are for music creation, graphics creation and gaming (mainly MMO and RPG). In terms of time spent it is mainly gaming, browsing and YouTube watching. What monitors would people recommend that would cover the majority of these uses to some degree? I would not be interested in wide or ultrawide screens or in curved monitors btw. Budget would be anything up to £500. Also big plus if it comes with VESA mount option, Displayport and a decent refresh rate.
Do you want to move to 1440p for the extra sharpness that resolution brings? In that case I'd be looking at a 27" panel.
If you're happy with the sharpness of the image your 1080p display produces then you could go 1440p on a 32" monitor for the extra size.
In terms of panel types, VA has good colour reproduction and the best contrast and black levels outside of an OLED but suffers from 'black smearing' in fast scenes. IPS handles fast motion better so is good for gaming and has good colour reproduction but suffers with washed out blacks and IPS glow.
The Gigabyte models are very good value. I can link to some recommendations based on your answers to the above.
27" for the extra sharpness would be the ideal! Unless a VA came with a flat screen then it seems my options are IPS based. I know many reviews for IPS say that they do not perform so well in dimly lit conditions, a place where my setup is currently situated, however my TN monitor has been perfectly fine.
So i think i have narrowed it down to the following monitors....
MSI 27" MAG274QRF-QD
LG 27" 27GP850P-B
GIGABYTE 27" M27Q V2
The MSI seem to be the best out of this bunch with better contrast than the LG and better than my Iiyama (1000:1) so better for my dimly lit room!
I bought the MSI this week, been using it the last 24 hour's.
Very impressed so far!
Can be had for less than £300 online with some simple searching :cool:
LG 27" 27GP850P-B
Any of those would be good options. I'd just shop around and buy the cheapest of the three.
The problem with IPS panels in dim lighting conditions is IPS glow (image search if you haven't already) which can make it hard to make out detail in dark scenes. If you put a lamp on in the room or put some form of lighting behind the monitor it will mitigate that a fair bit.
If your main use case is MMO and RPG gaming and other things that don't need fast motion then you'd almost certainly not run into the limitations of a VA panel and that may be a better buy.
My basket at OcUK:
Total: £377.17 (includes delivery: £0.00)​
Both of these are under £200 and worth consideration. You could always send it back within 14 days if you find the VA panel isn't suitable for your needs, but outside of fast paced FPS games it will have better contrast, more dark scene detail and perform better in dimly lit conditions than an IPS panel.
My basket at OcUK:
Interesting... The MSi VA is out as it is curved and my preference is for flat especially when working in Cubase and Inkscape. I would be interested in what the colour accuracy is with the AOC. Oddly enough the TN Monitor i currently have is quite fine in the dimly lit room so the MSI IPS should be fine. The LG less so given the reviews i have read...
I missed that the MSI VA was curved.
I have no idea on the AOC. They generally make pretty decent monitors though.
It sounds like you're fairly set on the MSI IPS. It got a recommendation above so go for it.
Heh, my heart was initially set on the LG, however the contrast element of RTings review knocked back my enthusiasm a bit. Gigabyte do an 27" M27Q X which is also a potential contender and i plan on getting some lighting behind the monitor to help mitigate any potential contrast issues! Thank you though for the recommendations. It is always good to get a sense check!
The LGs are known for not having the greatest contrast ratios, unfortunately. I used to have a 27" GN850 and found it fine though so your mileage may vary.
The MSI and Gigabyte units seem to review well when Hardware Unboxed take a look at them and they always win the best value products in their segment so I'm sure you'll be happy with either one. I'd just pick whichever of the two you can find cheapest.
Surprised no one mentioned the new dell 27"? Dell G2724D, IPS panel- I'd choose an IPS over TN every day of the week.
Another vote for the G2724D, picked one up at the current £200 price and I've been really impressed so far. No obvious issues, seems like a bargain!
