- 15 Nov 2024
- NE UK
Hi All
I have a MO-RA IV 400 on order, and was looking for some feedback on my plan to integrate this into my current setup.
I currently have an EK CPU & GPU Block (with active back plate), an FLT 240 w/D5 pump and a single thick (X series) 420 rad.
Whilst the above generally works fine and stays relatively cool, longer gaming session can push the temps up, so I have ordered the MO-RA IV.
My doubts are generally around loop order and pump requirements. I also have a second EK FLT w/D5 pump and was planning to attach both to the MO-RA inlet/outlet respectively, will this be enough to keep a decent flow rate through this kit?
Additionally, should I keep the X420 rad in the loop as its already fixed to my Thermaltake Core P5 case? It could fit pretty much anywhere into the loop, even between the CPU & GPU block. Would this serve a purpose, or would it just be pointless overkill?
All thoughts welcome
cheers
M
cheers
M
