Hi guys, really hope someone can help.
Last night all of a sudden me and Mrs had to both resign in to WiFi networks on phones. Later on the same night turned pc on, no Internet "unknown network".
-I have constant green led and occasionally orange flash at mobo end.
- I watch as I plug cable in on control panel > network and Internet > network connections >
And it shows "identifying" sometimes for 40secs or just goes straight to "unidentified network".
Shows as unidentified network
"ethernet public network"
It did work at one point tonight for 5 mins, then stopped without me changing anything.
Most of the time, problems found on windows10 diagnosis tool:
"ethernet doesn't have a valid ip configuration"
"investigate router or broadband modem issues - the failed
Reset the ethernet adapter - completed
Once I have also seen:
"an ethernet cable is not properly plugged in or might be broken". "plug an ethernet cable into the network adapter" but see that even when I can see the connection is there so no idea why it thinks nothing is plugged in. 2 cables tried also.
Tried...
-all ports on rear of router
-new ethernet drivers
-factory reset router
-calling virgin media
-several ethernet cables
-renaming the connection to "Vladimir Computin" (as it was before the router factory reset, as connection is still named this on the laptop)
In network connections I see:
Vladimir Computin
Unidentified network
Realtek PCIe GbE Family Controller
Status.
IPc4 connectivity - no network access
IPv6 connectivity - no network access
Media state : enabled
Speed = 1Gbps
Sent = 0 Bytes
Received = 1180 Bytes
Next to try...
-a copy of Windows from another ssd
-no idea
Mobo is an Asus x570-p.
Thanks in advance for any ideas guys, I'm so stressed about this one.
Tried...
Vladimir Computin
Status.
Speed = 1Gbps
Sent = 0 Bytes
Next to try...
-no idea
