Hi there,
I'm running low on space and need to upgrade my storage, I'm thinking of getting an M.2 SSD as a gaming drive, but just wanted to check before I did to make sure it will work with my setup, as I've never used an M.2 drive before!
I have a Gigabyte Z97X-UD5H-BK board, and currently have 2 SATA SSD's and 4 HDD's, so I'm using all of the SATA cable slots. The M.2 drive i'm looking at is something like the Intel 600p PCIe, will it be compatible with my board? I'm not sure if I should get an M.2 PCIe or an M.2 SATA?
According to the gigabyte website the board has one M.2 PCIe connector, but it also mentions that "The SATA3 4/5 connectors will become unavailable when an M.2 SSD is installed." Which I'm not sure about, because I don't want to not be able to use 2 of my drives. Here's the full info:
Also on a bit of a side note, would I be able to use the SATA Express connector for a 7th SSD/HDD? as an alternative.
Thanks in advance
Storage Interface
Chipset:
Marvell® 88SE9172 chip:
- 1 x M.2 PCIe connector
(Socket 3, M key, type 2242/2260/2280 SATA & PCIe SSD support)- 1 x SATA Express connector
- 6 x SATA 6Gb/s connectors (SATA3 0~5)
(M.2, SATA Express, and SATA3 4/5 connectors can only be used one at a time. The SATA3 4/5 connectors will become unavailable when an M.2 SSD is installed.)- Support for RAID 0, RAID 1, RAID 5, and RAID 10
* Due to system limitation, Intel RAID and Marvell RAID can only use either one.
- 2 x SATA 6Gb/s connectors (GSATA3 6~7)
- Support for RAID 0 and RAID 1
Thanks in advance
