M.2 to WiFi card is it a thing
1 Mar 2024
Leeds
So I just put a vertical mount in my pc and thought poo… where dose my WiFi card go
My WiFi card is a TP Link WiFi 6 card and if possible I’d still like to use it.
Board is a b450 aorus pro, was think about the second m.2 slot
the pcie card is just an adaptor but wifi card is the same as you get in a laptop i know it wont fit into the m.2 slot as i tried and it smaller.
i was wondering if there is an adaptor and if so what type do i need
Ah yeah that will work sorry. You'll need to connect the antenna somehow though, do they plug in to the small card or the PCIE adaptor?
into the card. the vertical mount as a honeycomb on the back so i should be ok to force the mount into that. i just ordered some 60mm ones as the 15mm on the card itself wont reach
It’s a little card lol… don’t know the right name. But in a pcie x1 adapter board
Isn't this NGFF or whatever it's called? There are NGFF to m.2 adapters but no idea how well they will work.
Edit: Wait just looked it up, m.2 was called NGFF, but it's just a different key for this WiFi card. I had to look for "NGFF antennas" when I was replacing a friend's WiFi antennas that broke off from the PCIe bracket.
this is the card i have and it works amazing, everything i have tried as always been poor this why id like to keep it, but im open to better ideas if there is any
