M4 / SATA 3 help
3 Sep 2010
OK so I have a 128Gb drive installed. When I start up the PC I check in the IRST and my new drive shows up as connected at 6Gb/s.
I can bench at this speed and I am getting 530 Mb/s seq reads which is all well and good.
That is until I check the port speed again to find it is now at 3Gb/s. The only way to get back to SATA 3 is to restart.
I have installed the latest drivers on the P67 Asus pro using the Intel ports (grey).
Any ideas?
Thanks
Edit : ( Not running the bench mark and the speed is staying at 6Gb/s )
