MAC Pro SSD upgrade
10 Dec 2014
Hi all,
my old man has an Mac Pro from late 2009/2010.
Now I can’t get to his house to take a look and can’t see much online regarding it but he would really like to upgrade from the hdd to ssd.
could anyone recommend to me an ssd and I believe that for the Mac Pro it might need some sort of caddy?
Thanks
The 2009/2010 Macpro uses slide out trays to hold the HDDs and bolt to the underside 4 mounting holes on the drive, so you will need an adapter that has those rather than the side mount holes. I have an Icybox Mb882sp-1s-1b or similar which works perfectly.
As for SSD I'd imagine a decent branded 1tb drive is easily within budget.
