Major Build Problem
24 Nov 2006
:mad: Major Build Problem
I got my E6600, tuniq heatsink, gigabyte ds4, 2gb geil ram, 1950xt today
i just assembled everything together, turn the psu on......and nothing, iv checked again and again, but no lights come on at all, no fans come on either.
The only thing i noticed was a burning smell so i quicky turned it off, it seemed to be coming from the psu but im not enterly sure
I need help, iv built my last rig fine so i dont know whats up with it, the psu is a coolermaster 650w and i used it in pc im on now before i got my new parts.
Im working nightshift tonight and dying to get it to work before i head off. its drivin me mad :mad:
i do, though i dont understand how the psu can fail already, it was working earlier today, i took it out one pc into the new one. my old psu doesnt have sata connectors, or pciexpress, so il need to move loadsa stuff about.
Has anyone experienced this before and it was the psu?
im just ******** it incase its the cpu thats fried or somethin
Have u connected the power/reset header correctly just double check to be sure. I get confused sometimes which is pos and which is neg :p
I know from experience that having the reset header the wrong way round that the button does nothing when pressed so same for the power? not sure :confused:
when i 1st switched it on i had gfx in as well, god im ****** off.
how long does it take to get replacements and so on, i can see that iv did nothing wrong at all, and i used an antistatic wrist strap..sooo frustratin :mad:
When i build my rig tomorrow i think i will use my old graphics card to install windows then when all is ok i will put my 8800gts in its the only way tobe sure.
i got a question, if its the cpu thats fried, would the mobo and fans still come on? also if it were the board , would it damage the cpu and gfx card as well? i really dont know what exactly is at fault
If the CPU was fried it would spell of the burning smell you state...does it smell of a horrible electrical burning smell? Check the CPU itself and make sure it hasnt got burn marks on it if I were you, just to rule out that from the equation before rma'ing the motherboard.
If the motherboard was fried you would also get the same signs in most cases, i.e. no vga output but it's weird you don't get anything from the motherboard POST analyser thingy...usually this would work....if it was the CPU, in 99% of cases, the fans would still spin up but you would get no vga output but no, it wouldn't damage the graphics card.
hope this helps
ghgh
