Ive only had a brief play with mantle in online bf4. Tbh it felt a bit smoother, but then for online the system on which i used mantle was connected to an 80mb fibre line. If i get on a decent server on my own adsl connection, bf4 under dx plays grand too.That's the way I look at it but people will use whatever tools they can grasp at to make fallacious points in favour of their preferred GPU brand. Having tried both of them very recently there just wasn't any perceptible difference for me between the two brands Mantle included. Both DX through nVidia and Mantle through AMD worked well and felt smooth.
Its quite funny in late 2012 and earlu 2013 when the Never Settle driver came out and websites found frametime issues with some of the AMD drivers,people were all over it saying AMD crap drivers.
Now the same review sites,say the AMD driver might even be better than Nvidia in a number of games,the frametime charts don't matter anymore.
LOL.
Its quite funny in late 2012 and early 2013 when the Never Settle driver came out,and the releases clustered right after them and websites found frametime issues with some of the AMD drivers,using both the TR methodology and the one that PCPER helped develop with Nvidia,people were all over it saying AMD crap drivers,etc. Runt frames(as Nvidia called them for the dual card results) and all that stuff.
Now that the same review sites,say the AMD drivers might even be better than Nvidia in a number of games,the frametime charts don't matter anymore.
LOL.
I think you will find that amd users said that all there games where smooth anyway and this info is meaningless, Not so meaningless now is it?
LOL
so his graph goes 5, 10, 16?
Dont think so, it goes 5,10,15,20,25 clearly, so he has only a few result over 16 and even where they are he has none ranging to 40+ unlike you
If results dont lie then the nvidia graph very clearly shows less skipping and skipping of a shorter duration![]()
For our multi-GPU testing,at 2560x1440, the AMD Radeon R9 290X cards in CrossFire showed much more frame time variance than the GTX 980 cards running in SLI. So even though the average frame rate of the 290X CF combo was higher, the better experience was clearly on SLI.
http://www.pcper.com/reviews/Graphi...and-GTX-970-GM204-Review-Power-and-EfficiencyThat isn't the case at 4K though where frame time variance is actually better on the AMD solution - things have been swapped!
Indeed there were comments like that as they did not have a first hand comparison beforehand, but lets not make out that they have changed there mind after the experience only recently, it started to matter quite some time ago.
I held my hands up and ate the humble pie when first ran SD on the fixed frame latency drivers-night and day.
I also remember a (vocal)user in this very thread stating you couldn't mine because 'crossfire doesn't give you better results than a single card' and posted PCP's dual setup gaming expose as proof at the time.
Some of you should have a read over this: http://international.download.nvidia.com/geforce-com/international/pdfs/FCAT_Reviewer's_Guide.pdf
Nvidias reviewer guide on using FCAT, going by the information in that PDF, the frame time tools we use here on this forum are largely irrelevant. Measuring the wrong thing at the wrong time.
If someone wants to pony up £1500+ on a capture card and raid SSD setup capable of accurately measuring frame times feel free![]()
But am not using FCAT? my results are coming right from the Battlefield Engine. Perfoverlay.framefilelog 1
Capturing displayed frames is very difficult. If you control the driver, it can be done with software. But
drivers can be written to hide effects like dropped and runt fames. What is required is a method that
measures the actual output from the DVI connector before it’s delivered to the monitor.
Software tools, like Fraps, actually capture frames from the frame buffer off the GPU. However, this
data is not what you see: it is not representative of everything that is seen on the display. There is
actually a process called scan out, and that is the difference. What FCAT is measuring is what is
happening right at the display, as opposed to what is in the frame buffer.
So you have to look at Mantle vs DX FCAT results.
We know from PCper's DirectX FCAT comparisons that AMD are at least as good as Nvidia on DirectX, both are good.
Neither are as good as Mantle.
snip
Almost perfect ^^^
LOL.
Read the PDF!
Perfoverlay.framefilelogenable 1 will be reading from the frame buffer.
I've never disputed Mantle gives more consistent (thus smoother) frame times. In fact me and matt did some testing many months ago and came to the same conclusion. Even in circumstances where min/max/avg were equivalent to DX, frame variance was sufficiently different.
