- 25 May 2016
- North wales
Thankyou just got abit worried that it needed to be plugged into the wall sockets,
My plan is to use my surge protector.
Why on earth does a router need to be plugged into a wall socket? They're typically 12v or so, not power guzzling tumble driers. Are you thinking of woodworking routers?
Or a 2000W 1/2" heavy duty router with Powerline ethernet for real time hardware monitoring!Routers | Power Tools | Screwfix.com - OP might be trying to plug one of these in.
Oh since day one I was allways told I needed to put routers into wall sockets
so for over 20 years I could have stuck a Bt router into a surge block and not worry about any dropout etc ?
Ok will use the double wall socket, and have a surge protector in each one.
Seems most likely.I wonder if they / you got mixed up and were talking about the phone socket connection to the router and not the power connection as you wouldn't want the phone cable on an extension for example.
