Maths Help Please
15 Dec 2004
Hi,
Would someone mind helping me with a maths question I have? It's not a test or anything, it's just something our teacher has given us over the holidays to do. I've looked in my textbook and found nothing on the subject and have searched google only to find someone trying to flog me a programme :( Basically, the question is:
Factorise y=2x² - 7x -15 which I think I have done fine and got:
(2x + 3)(x - 5)
Then...
The graph of y=2x² - 7x -15 is sketched below:
(Excuse dodgey drawing :o)
Find the equation of the line of symmetry of this graph...
Anyone have any ideas? It's probably really simple but we haven't covered it yet so I would appreciate any help :)
Thanks
Ben
anksta said:
its half way between P and Q, like if P was -4 and Q was 6 then the equation of that line would be x=1
Yeah, but there are no values on the axis i've been given- they're just blank and I can't just write 'halfway between P and Q' as the answer lol :D :(
Thanks for the reply BTW :)
Ben
Yeah as anksta has said,
You need to find the points where y=0
so since youve factorised it you should be almost there.
KaHn
KaHn
Ahhh, I think I understand now. There should be two posible values for y=0 and the line of symmetry will be halfway in between them?
Thanks again
Ben
Thanks again
Ben
Yes basically equate both brackets to zero and work out them both seperatally for the two values of x.
KaHn
KaHn said:
/edit:- also your factorisation is wrong
How exactly?
y=2x² - 7x -15 --> (2x + 3)(x - 5)
If I multiply the bit in the brackets out I get what I started with :confused:
2x multiplied by x = 2x²
3 multiplied by x = 3x
-5 multiplied by 2x = -10x
and +3 multiplied by -5 = -15, so...
2x² + 3x -10x -15 = 2x² -7x -15 doesn't it? :confused: :(
Trigger said:
How exactly?
see my ninja edit :p
I looked at it quickly and weny b^2-4ac<0 hence imaginary but then i remembered the minus sign :)
KaHn
KaHn
hmmm, damn my slow keyboard skillz :o Sorry :( So would I be right in saying that the line of symmetry is x = -1?
Thanks
Ben
Thanks
Ben
No that is wrong.
You need to look a (2x+3)=0 and (x-5)=0
Then basically from those two equations what does x=?
KaHn
spirit said:
y=2x² - 7x -15
(2x - 3.5)^2 - 27.25
hence the line of symetry it gonna be 3.5/2 = 1.75
much easier to complete the square to find symetrys for quadratics.
Look at how the question is worded, factorise this then get the line of symmetry.
KaHn
..edited out something some already said, but i think my way is faster, eventho i made a stupid mistake first time round :)
KaHn said:
No that is wrong.
KaHn
Well that's what I did but wasn't sure whether it was x = 3 and x = -5 or if the 2x in (2x+3) had an effect on the 3 or not? But wouldn't that make it x = 1.5 and x = -5 ?
Thanks
Ben
