Maths Help Please
gord said:
so your saying 3.25 is the line of symmetry?
No im saying that 3.25 is the middle of that parabolic curve, so that is 3.25 further along from x=-1.5 would be the middle so the line of symmetry is x=1.75
KaHn
Factorisation and drawing graphics for quadtratic equations is dead easy if you know how to complete the square.
Assuming you do, if you complete the square of ax^2+bx+c then you'll get all the values you need to plot a graph and you'll get the solutions :)
KaHn
Yeh sorry, i didnt explain mine clearly.. i make it 1.75 too
KaHn
Ahh, I see now. It was because I was not dividing by 2 before in (2x+3) when I should have done so :o Anyways, thank you to everyone for their help, you've all been great :)
Thanks again :cool:
Ben
Notice also that if we complete the square (or differentiate) we find that x = 7/4 corresponds to a minimum. Since there is only one minimum it must be ON the axis of symmetry. We also know that to go from the graph of y = x^2 (which is symmetric in x=0) to your parabola we only need to do translations and stretches so the line of symmetry must stay vertical, hence it must be x = 7/4. This is probably more information than you need to know. For this question you can just use intuition really.
Edit: doesn't look like you need to bother with finding the turning point...
You could have just differentiated twice.
I'm curious to how that may be.
dy/dx would give you gradient
d^2y/dx^2 would give you the minimum and turning point and weather its an increasing or decreasing funtion.
Do you say this because d^2y/dx^2 will provide a minimum and turning point which will relate to x= the value of what you just differentiated twice?
You only need to differentiate once, it is completely irrelevant whether it is a maximum or minimum (or inflection) in this case as it it an X2 graph.
Aigh, you speak the truth. I reckon if he differentiatied once and made the gradient function equal zero then it would've worked as well.
It will d2y/dx2 will tell you what type of turning point it is, or help you figure it out. if its positive its a minimum, if its negative its a maximum, if its zero u need to check it
True, I had a brain fart: there's no real need to differentiate twice. :p
Been doing bloody fourier transforms all morning. :(
what was the formula that would find y=0, its something like -b +-((b^2-4ac)^-2)/2a or something. can't remeber what the equation was called.
Ohh how the greyt matter hurts for a slow monday at work.
Yup. x=7/4=1.75, same as averaging -1.5 and +5. Always best to double check.
daz said:
I prefer to "complete the square" rather than use the quadratic formula. :)
Completing is using the quadtratic formula but very subtly. When you do complete the square of a quadtratic you are in actual fact completing the square of ax^2+bx+c=0. The difference is a, b and c are numbers :)
If you dont believe me complete the square of ax^2+bx+c=0 ;)
Badger: Its x=(-b±"square root"b²-4ac)/2a
knew it was something like that, after 5 mins on excel remembered formula, was not sure where to put brackets, ahh well, just got to find the ASCII codes for the square root sign and +- sign then my afternoon of work has actually been useful for once.
It's easier to remember the method of completing the square rather than the quadratic formula, is what I was alluding to. :)
Arcade Fire said:
I love how these threads always get more complicated than they need to - how did we get onto differentiation?! ;)
We're finding turning points! :p
