Maths help please!
25 Aug 2006
The line with equation y=2x-k passes through the point (4 , 0). Work out the value of k.
Where do i start and what's the simplest way of remembering how to do these?
and more:
Simplify:
(1)0 (in brackets, 1 over p, outside brackets, to power of zero)
p
(r4)-2 (in brackets, r to the power of 4, outside brackets, to power of minus 2)
The point (4 ,0) is an x,y co-ordinate, x being 4 and y being 0.
Put these two numbers into your equation and you get 0=8-k. So, 8 minus something (k) equals 0. That means k must be 8. Simples!
(Just in case you don't know, the 2x in your equation means 2 times x which is how I got 8)
Algebra is one of the few things I was good at, Although the (4, 0) Threw me, But now I think about it, Its obviously co-ordinates.
I suck at maths on a grand scale, I'm sure if i was to take a maths GCSE i'd probably get a D or something :(
Substitute what you know
(4, 0 )
4 = X value
0 = Y Value
0 = (2 x 4) - k
0= 8-k
K = 8
EDIT: Should read before posting! :p
The answer to the (1/p)^0 one is 1 since anything to the power 0 is 1.
As for (r^4)^{-2} you just add the powers, so the answer is r^2 (where ^ denotes powers)
Edit: as Jay Psi pointed out I'm an idiot and got the second part wrong:rolleyes:. See further down for correct answer
Okay, it's been a few years, but are you sure about this? IIRC, raised indices are multiplicative, so (r^4)^(-2) = r^(4*-2) = r^(-8) = 1/(r^8).
If it was (r^4)*(r^-2) then the answer would be r^2 [as the OP had in 16 (b), where (q^5)*(q^3) = q^(5+3) = q^8]. Unless I've dropped a *BIG* one there :o
EDIT - These algebraic simplifications can be done on certain calculators, but I'm confident they're not allowed for your exams
