Maths problem - how do you solve it.
greenlizard0 said:
Sod it I'm drunk go for it fella ;)
Yeah with the way you are doing it....im sure you get more than one answer 60 and 50 both work using the method which i am sure you are doing
TURNS OUT I WAS WRONG WITH MY CALCULATIONS.....still need an answer
I'm pretty trashed now, but bookmarking this for tomorrow because I couldn't work it out in the couple of minutes that I stared at it, which probably means that it's hard - and therefore interesting. ;)
Google says...
"Triangle Problem 1 Small Hint
To solve the problem, you will need to draw a few more lines inside the triangle.
You will need to do more than "chasing angles" with the 180 degree rule.
The solution has more steps than you might expect."
This is as far as I got
Cheetah Designs said:
Lol.....link it....just incase people want to work it out.....ruined it for me now i've had the hint althought actually posting it here......lol i see your point.....just link just incase people want to work it out.
Page only had that hint, no solution :p
New hint: "This cannot be solved without drawing extra lines and any attempt to do so is just a lesson in frustration."
