SOLUTION - SPOILER, SKIP PAST IF YOU DON'T WANT TO KNOW.
1- Make a parallel to AB from D. DF parallel to AB
2- AF and DB intersects at the point O, the parallel logic makes that BAF = 60 = ABD = AFD = FDB, and also CFD = CBA = 80
3- Take a look at the triangle ABE. If we try to find the point G, which is the centre of the circle in which this triangle inserts, we get: GE = GA = GB.
By simple mathematics calculate: GÂB = GBA = a
GAE = GEA = b
GEB = GBE = c
a+a+b+b+c+c (the sum of the angles of the triangle ABE) = 180
a+b+c = 90
a+b = BAE = 70
b+c = AEB =30
c+a = EBA = 80
a+b+c = 70+c=90
so, c = 20, a = 60 , and b = 10
(If you draw the lines and see the points it'll be very easy…)
So, the centre of this triangle G forms GAB = GBA = 60. We can see that this point coincides with the point O, in fact G =O. so we have now, O , previously drawn , is the centre of this triangle AEB, so OE = OA = OB
4- We had already, BEO = 20 (the c angle) = FEO
The angle AFC = CFD + DFA = 80 + 60 =140
So in the triangle FEO, we have, 140, 20 and the last angle to find, FOE = 20
So FOE is an isosceles triangle, so, FO = FE
5- We have the triangle ODF, equilateral one (all 60 degrees) so OF =OD =DF
6- From 4 and 5 we can deduce that, FE = FD, isosceles triangle with EFD = 80, so each of FED = FDE = 50 degrees.
7- FED = FEA + (our famous angle) so, 50 = 30 + (our famous angle, I'll call it x, or AED)
8- x = 20 degrees.
END SOLUTION
