matrox triplehead2go help
10 Oct 2008
I just got a triplehead2go but sadly just about every mode bring out a "out of range" message on my LG W2246 monitors. It is running at 800x600 on 3 monitors at the moment but any higher then that and it says out of range or i just just a mad imange. Am i doing something wrong? thanks
Your monitors appear to have only VGA (D-Sub) connections.
Looking at the product page for the TripleHead2Go it states:
Maximum VGA Resolution 4080x768 (3x 1360x768)
Presumably there's some way to get different than 800x600 on each monitor (i.e a 16:9 aspect ratio) but unfortunately it wouldn't appear that you're going to get anywhere near 1920x1080.
