You are supposed to set up 2 profiles, one stock and one OC so Powerplay can still work. Afterburner detects 3D applications and switches to your OC profile, then loads your stock settings back once all 3D apps are quit. Powerplay will then kick in like normal. No need to load Afterburner every time you play a game.
I have mine @ 1050 / 1200 / 1.3v. Will try for more this afternoon, however I don't see the point of clocking the memory at all - it makes no difference and creates an unnecessary point of failure for your OC, PLUS it's hard to tell when the error detection is kicking in, resending data and causing framedrops.
I have 2 profiles set up and when Afterburner is enabled powerplay isn't. Tested it yesterday. When I revert to default values (profile nr 1) it stays on the same level all the time(755/1125), ie no powerplay. What's more, even disabling Afterburner altogether won't help, only when I restart PC I have full control of CCC Overdrive and powerplay back (MSI Afterburner 1.50).
I should probably add my card is not MSI or ATI, it's XFX HD 5850 XXX edition and I did not flash the bios.
