Hope if got the right forum - this is a technical query........
I've got two Maxtor 160gb sata drives in my pc (had for just over a year now) and recently I've been having problems with them.
Sometimes, with no pattern, when I go to the drives either saving or opening a file windows says that the file I'm opening or saving (or the location) has become currupt and all data on the drive becomes no longer visable in windows.......... a few seconds later the whole system freezes. When I reboot windows fails to load, until I turn the PC off then start again and its fine.
When the problem happends, I lose all visability of files on the drive (its happened on both drives now) but when I reboot everything is there.
Is this hard drive issue or could it be the motherboard playing up? anyone else experianced this?
Cheers,
Dan
Cheers,
Dan
], alternatively they both could have been damaged during delivery - again if you got them at the same time. Third theory is something has happened to them both while you have had them - nasty shock while in use, power failure, power surge from iffy PSU... fourth theory is that Maxtors are basically crap
