And they don't even have enough chemicals to do that thanks to Brexit.As far i know it treated and then piped into the ocean
The sewage pipe work and clean water pipe work is completely different pipe works so i can't see how they could do this even if they wanted to
Yeah I'm sorry but I wouldn't trust any of these private companies to handle something like this. They'll do the bare minimum like you say, and then something will eventually go wrong, probably in a completely preventable way and people will get sick or possibly even die and the company will get a tiny slap on the wrist and then things will continue on as normal until the next incident.yea filtered by the earth.
I wouldn't trust any of the water companies when it comes to treated sewage directly entering the water supply lines....
look how they all skimp on costs, do the bare minimum and dump in the sea/rivers because it's cheaper than building temporary storage.
you really trust them to filter water 100%? what if they can get away with 95% and a few people get dheli belly or whatever.... if it saves a few million and they can get away with a small fine or whatever you know they would just do it.
before anyone comes in with "but nasa filters pee etc" yea and I'm sure to a ridiculously high standard with nothing left to chance to save on costs...
if tories are still in power they will just lower the quality levels needed so these companies don't get fined, the owner has to donate to the party thoughYeah I'm sorry but I wouldn't trust any of these private companies to handle something like this. They'll do the bare minimum like you say, and then something will eventually go wrong, probably in a completely preventable way and people will get sick or possibly even die and the company will get a tiny slap on the wrist and then things will continue on as normal until the next incident.
Made from water.I was going to start drinking water but after that I think I’ll stick to beer
Made from water.
They used to do that in days or yore when water was foul and beer was weaker, i guess the small amount of alcohol killed the bacteria.
Beer is made from hopsTLDR: Drink beer not water.
Made from water.
And they don't even have enough chemicals to do t thanks to Brexit.
Deny it all you want, there is a shortage of chemicals in GB to treat water due to difficulties arising from Brexit.I stubbed by toe this morning, bloody brexit!
AND PUT IN THE BOTTLEThe local farms have been spraying human **** over the fields for years and apart from the odd bit of sweetcorn in the carrots, it has not been a problem.
Was trying to find the Grand Designs episode where a system of lakes, gravel and reeds meant that the waste was always being recycled.
