ddr2 when you can get ddr3 atm for the same price = fail.
sorry, bad config for the money you can do much better
You can't say that without suggesting another!
I'm thinking of DDR3, but i am open to idea's
Cheers
You cant.
show me then..
my setup was 5 pound difference with ddr3, you cannot beat that on a ddr2 system for 5 pound the fiver for ddr3 it worth it.
i'd go with the x4 620 setup that lemzip suggested, the 785g's onboard gfx are decent unless your gaming (which you have already said is not what its for) and as new software is already getting optimized for multiple cores the x4 will out perform the phenom x2's in most things.
Yes. But you are comprimising on the cpu.
You will notice a speed increase from dual - quad.
But almost nothing going from ddr - ddr3
fail.
AMD Athlon II X4 Quad Core 620 2.60GHz (Socket AM3) - Retail £81.99![]()
(£69.78) £81.99
(£69.78)OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 Low-Voltage Dual Channel (OCZ3G1333LV4GK) £71.51![]()
(£60.86) £71.51
(£60.86)Asus M4A78LT-M LE AMD 760G (Socket AM3) PCI-Express DDR3 Motherboard £57.99![]()
(£49.35) £57.99
(£49.35) Sub Total : £179.99 Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.00 VAT is being charged at 17.50% VAT : £33.07 Total : £222.06
