I like Hardware Unboxed but i think Steve's obsession with VRMs even on mid and lower end Motherboards is becoming a problem.
Essentially what he does is take a £120 motherboard and stress test a 3950X in it, if the VRMs biol the motherboard's no good...
On a high-end board yes sure... but on a budget board? Ridiculous...
Here's the thing, if reviewers start making it all about how well VRMs handle high-end CPU's then those vendors will improve those VRMs, high quality VRMs are expensive, vendors are not going to absorb that cost, they will pass it on to you or you will get fewer features, or a combination of both.
If i'm looking for a £120 Motherboard its not for a 3950X, as long as the VRMs can run a 3700X its fine.
Way back when Steve reviewed the Motherboard that i now own, he dropped an 1800X in it, overclocked the proverbials off it and concluded "its crap, don't buy it the VRMs are junk" i'm paraphrasing...
I ignored him and bought it, it was £90. It has:
2X USB2
4X USB3
2X USB3.1
1X USB Type C
PS2
2X M.2
X4 RAM Dimms
8X Sata
4X PWM Headers
And the usual
DVI
D-Sub
HDMI
RJ-45
Line In
Audio Out
Lots and lots of connectivity, including all 3 Video out types, 2X M.2 of which both are in use.
I have had it for 3 and a half years, i have the RAM tuned to within an inch of its life and it has never put a foot wrong, i haven't been in the BIOS since in installed the 3600 more than a year ago, i do a lot of high stress work with it and the VRMs never go much over 70c while rated at 125c.
It is the most solid and stable board i have ever owned.
Steve said its junk, don't buy it... all because it couldn't handle the VRMs being abused.
With sub $150 boards you're going to get the features you need or overkill VRMs, not both, those are high end boards, and if reviewers place too much emphasis on VRMs you're going to get good VRMs but no features.
