MBR damaged
6 Nov 2005
Aberdeenshire
I was defragging when the power went out. God damn card meters!!
Now when I boot up my second 250GB WD Sata2 drive doesn't show in my computer. When I go to disk management it says it is unreadable. I'm assuming that the MBR was damaged or lost when the power went.
Is there any program I can use to recover or repair the MBR as there's a lot of stuff on that drive I don't want to loose.
I don't know if Seatools repairs the mbr on a drive apart from the OS drive....but you can have ago.
http://www.seagate.com/support/seatools/
You can also search for a program called Hirens Boot CD this as plenty of Hard drive tools installed on it.
Download it from here
Code:
http://webprod2.megashares.com/index.php?d01=b5b6da3&sq=&d01go=1&fln=/Hiren_s_BootCD_8.5.rar
Release date: 01-10-2006
Type: BootCD
URL: http://thanki.tk
All-in-one bootcd with the following contents:
Partition Tools
Partition Magic Pro 8.05
Best software to partition hard drive
Acronis Disk Director Suite 9.0.554
Popular disk management functions in a single suite
Paragon Partition Manager 7.0.1274
Universal tool for partitions
Partition Commander 9.01
The safe way to partition your hard drive,with undo feature
Ranish Partition Manager 2.44
a boot manager and hard disk partitioner.
The Partition Resizer v1.3.4
move and resize your partitions in one step and more.
Smart Fdisk 2.05
a simple harddisk partition manager
SPecial Fdisk 2000
SPFDISK a partition tool.
eXtended Fdisk 0.9.3
XFDISK allows easy partition creation and edition
GDisk 1.1.1
Complete replacement for the DOS FDISK utility and more.
Disk Clone Tools
ImageCenter 5.6 (Drive Image 2002)
Best software to clone hard drive
Norton Ghost 8.3
Similar to Drive Image (with usb/scsi support)
Acronis True Image 8.1.945
Create an exact disk image for complete system backup and disk cloning.
Partition Saving 3.20
A tool to backup/restore partitions. (SavePart.exe)
COPYR.DMA Build013
A Tool for making copies of hard disks with bad sectors
Antivirus Tools
F-Prot Antivirus 3.16f (0410)
Very good virus scanner (with ntfs support and easy to use menu)
McAfee Antivirus 4.40 (0410)
a virus scanner (with ntfs support and easy to use menu)
Recovery Tools
Active Partition Recovery 3.0
To Recover a Deleted partition.
Active Uneraser 3.0
To recover deleted files and folders on FAT and NTFS systems.
Ontrack Easy Recovery Pro 6.10
To Recover data that has been deleted/virus attack
Winternals Disk Commander 1.1
more than just a standard deleted-file recovery utility
TestDisk 6.5b
Tool to check and undelete partition.
Lost & Found 1.06
a good old data recovery software.
DiyDataRecovery Diskpatch 2.1.100
An excellent data recovery software.
Prosoft Media Tools 5.0 v1.1.2.64
Another excellent data recovery software with many other options.
PhotoRec 6.5b
File and pictures recovery Tool.
Testing Tools
System Speed Test 4.78
it tests CPU, harddrive, ect.
PC-Check 6.0
Easy to use hardware tests
Ontrack Data Advisor 5.0
Powerful diagnostic tool for assessing the condition of your computer
The Troubleshooter 7.02
all kind of hardware testing tool
PC Doctor 3.0
a benchmarking and information tool
Test Cpu/Video/Disk 5.6
a tool to test cpu, video, and disk
Test Hard Disk Drive 1.0
a tool to test Hard Disk Drive
RAM (Memory) Testing Tools
DocMemory 3.1b
RAM Test utility
GoldMemory 5.07
RAM Test utility
Memtest86+ 1.65
PC Memory Test
Hard Disk Tools
Hard Disk Diagnostic Utilities
Seagate Seatools Desktop Edition 3.02
Western Digital Data Lifeguard Tools
Western Digital Diagnostics (DLGDIAG) 5.04f
Maxtor PowerMax 4.23
Maxtor amset utility 4.0
Maxtor(or any Hdd) Low Level Formatter 1.1
Fujitsu HDD Diagnostic Tool 6.61
Fujitsu IDE Low Level Format 1.0
Samsung HDD Utility(HUTIL) 2.02
Samsung Disk Diagnose (SHDIAG) 1.28
IBM/Hitachi Drive Fitness Test 4.08
IBM/Hitachi Feature Tool 2.03
Gateway GwScan 3.15
ExcelStor's ESTest 3.80
MHDD 4.6
WDClear 1.30
Toshiba Hard Disk Diagnostic 2.00b
HDD Regenerator 1.51
to recover a bad hard drive
Ontrack Disk Manager 9.57
Disk Test/Format/Maintenance tool.
Norton Disk Doctor 2002
a tool to repair a damaged disk, or to diagnose your hard drive.
Norton Disk Editor 2002
a powerful disk editing, manual data recovery tool.
Active Kill Disk 1.1
Securely overwrites and destroys all data on physical drive.
HDAT2 4.5.2
main function is testing and repair (regenerates) bad sectors for detected devices
SmartUDM 2.00
Hard Disk Drive S.M.A.R.T. Viewer.
Victoria 3.33
a freeware program for low-level HDD diagnostics
System Information Tools
Aida16 2.14
a system information tool, extracts details of all components of the PC
PCI and AGP info Tool (0410)
The PCI System information & Exploration tool.
System Analyser version 5.3o
View extensive information about your hardware
Navratil Software System Information 0.59.9
High-end professional system information tool
Astra 5.21
Advanced System info Tool and Reporting Assistant
HwInfo 5.0.3
a powerful system information utility
PC-Config 9.33
Complete hardware detection of your computer
SysChk 2.46
Find out exactly what is under the hood of your PC
CPU Identification utility v1.12
Detailed information on CPU (CHKCPU.EXE)
CTIA CPU Information
another CPU information tool
MBR (Master Boot Record) Tools
MBRWork 1.07b
a utility to perform some common and uncommon MBR functions
MBR Tool 2.2.100
backup, verify, restore, edit, refresh, remove, display, re-write...
DiskMan4
all in one tool for cmos, bios, bootrecord and more
BootFix Utility
Run this utility if you get 'Invalid system disk'
MBR SAVE / RESTORE 2.1
BootSave and BootRest tools to save / restore MBR
Boot Partition 2.60
add Partition in the Windows NT/2000/XP Multi-boot loader
Partition Table Doctor 3.0
a tool to repair/modify mbr, bootsector, partition table
Smart Boot Manager 3.7.1
a multi boot manager
Bootmagic 8.0
This tool is for multi boot operating systems
MBRWizard 2.0b
Directly update and modify the MBR (Master Boot Record)
BIOS / CMOS Tools
CMOS 0.93
CMOS Save / Restore Tool
BIOS Cracker 4.8
BIOS password remover (cmospwd)
BIOS Cracker 1.4
BIOS password remover (cmospwc)
BIOS Utility 1.35.0
BIOS Informations, password, beep codes and more.
!BIOS 3.20
a powerfull utility for bios and cmos
DISKMAN4
a powerful all in one utility
UniFlash 1.40
bios flash utility
Kill CMOS
a tiny utility to wipe cmos
MultiMedia Tools
Picture Viewer 1.94
Picture viewer for dos, supports more then 40 filetypes.
QuickView Pro 2.57
movie viewer for dos, supports many format including divx.
MpxPlay 1.54
a small Music Player for dos
Password Tools
Active Password Changer 3.0
To Reset User Password on windows NT/2000/XP/2003 (FAT/NTFS)
Offline NT/2K/XP Password Changer
utility to reset windows nt/2000/xp administrator/user password.
Registry Viewer 4.2
Registry Viewer/Editor for Win9x/Me/NT/2K/XP
Registry Reanimator v1.02
check and restore structure of the damaged registry files of NT/2K/XP
NTPWD
ATAPWD 1.2
Hard Disk Password Utility
NTFS Ext2FS, Ext3FS (FileSystems) Tools
NTFS Dos Pro 5.0
To access ntfs partitions from Dos
NTFS 4 Dos 1.4
Paragon Mount Everything 3.0
To access NTFS, Ext2FS, Ext3FS partitions from dos
NTFS Dos 3.02
EditBINI 1.01
to Edit boot.ini on NTFS Partition
Dos File Managers
Volkov Commander 4.99
Dos File Manager with LongFileName/ntfs support
(Similar to Norton Commander)
Dos Command Center 5.1
Classic dos-based file manager.
File Wizard 1.35
a file manager - colored files, drag and drop copy, move, delete etc.
File Maven 3.5
an advanced Dos file manager with high speed PC-to-PC file
transfers via serial or parallel cable
FastLynx 2.0
Dos file manager with Pc to Pc file transfer capability
LapLink 5.0
the smart way to transfer files and directories between PCs.
Dos Navigator 5.9.0
Dos File Manager, Norton Commander clone but has much more features
Mini Windows 98
Can run from Ram Drive, with ntfs support,
Added 7-Zip which supports .7z .zip .cab .rar .arj .gzip,
.bzip2 .z .tar .cpio .rpm and .deb
Disk Defragmenter, Notepad / RichText Editor,
Image Viewer, .avi .mpg .divx .xvid Movie Player, etc...
Other Tools
Ghost Walker 2003.793
utility that changes the security ID (SID) for Windows NT, 2000 and XP
DosCDroast beta 2
Dos CD Burning Tools
Universal TCP/IP Network 5.8
MSDOS Network Client to connect via TCP/IP to a Microsoft based
network. The network can either be a peer-to-peer or a server based
network, it contains 85 different network card drivers
Dos Tools
USB CD-Rom Driver 1
Standard usb_cd.sys driver for cd drive
Universal USB Driver 2
Panasonic v2.20 ASPI Manager for USB mass storage
SCSI Support
SCSI Drivers for Dos
1394 Firewire Support
1394 Firewire Drivers for Dos
Interlnk support at COM1
To access another computer from COM port
Interlnk support at LPT1
To access another computer from LPT port
and too many great dos tools
very good collection of dos utilities
extract.exe pkzip.exe pkunzip.exe unrar.exe rar.exe
ace.exe lha.exe gzip.exe uharcd.exe mouse.com
attrib.com deltree.exe xcopy.exe diskcopy.com imgExtrc.exe
undelete.com edit.com fdisk.exe fdisk2.exe fdisk3.exe
lf.exe delpart.exe wipe.com zap.com format.com
move.exe more.com find.exe hex.exe debug.exe
split.exe mem.exe mi.com sys.com smartdrv.exe
xmsdsk.exe killer.exe share.exe scandisk.exe scanreg.exe
guest.exe doskey.exe duse.exe biosdtct.exe setver.exe
ntersvr.exe interlnk.exe loadlin.exe lfndos.exe doslfn.com
Windows Tools
SpaceMonger 1.4
keeping track of the free space on your computer
Drive Temperature 1.0
Hard Disk Drive temperature meter
Disk Speed 1.0
Hard Disk Drive Speed Testing Tool
MemTest 1.0
a Memory Testing Tool
PageDfrg 2.32
System file Defragmenter For NT/2k/XP
WhitSoft File Splitter 4.5a
a Small File Split-Join Tool
Ghost Image Explorer 8.3
to add/remove/extract files from Ghost image file
DriveImage Explorer 5.0
to add/remove/extract files from Drive image file
Drive SnapShot 1.37
creates an exact Disk Image of your system into a file while windows is running.
Active Undelete 5.1.010
a tool to recover deleted files
Restoration 2.5.14
GetDataBack for FAT 2.31
Data recovery software for FAT file systems
GetDataBack for NTFS 2.31
Data recovery software for NTFS file systems
Startup Control Panel 2.8
a tool to edit startup programs
Startup Monitor 1.02
it notifies you when any program registers itself to run at system startup
IB Process Manager 1.04
a little process manager for 9x/2k, shows dll info etc.
Pocket KillBox 2.0
can be used to get rid of files that stubbornly refuse to allow you to delete them
HijackThis 1.99
a general homepage hijackers detector and remover and more
RootkitRevealer 1.7
Rootkit Revealer is an advanced patent-pending root kit detection utility.
Silent Runners Revision 48
A free script that helps detect spyware, malware and adware in the startup process
Autoruns 8.53
Displays All the entries from startup folder, Run, RunOnce, and other Registry keys,
Explorer shell extensions,toolbars, browser helper objects, Winlogon notifications,
auto-start services, Scheduled Tasks, Winsock, LSA Providers, Remove Drivers
and much more which helps to remove nasty spyware/adware and viruses.
CurrPort 1.07
displays the list of all currently opened TCP and UDP ports on your computer
Unknown Devices 1.2 (0410)
helps you find what those unknown devices in Device Manager really are
PCI 32 Sniffer 1.1 (0410)
device information tool (similar to unknown devices)
NewSID 4.10
Double Driver 1.0
Driver Backup and Restore tool
CPU-Z 1.37
It gathers information on some of the main devices of your system
CWShredder 2.19
Popular CoolWebSearch Trojan Remover tool
Winsock 2 Fix for 9x
to fix corrupted Winsock2 information by poorly written Internet programs
XP TCP/IP Repair 1.0
Repair your Windows XP Winsock and TCP/IP registry errors
CCleaner 1.33.382
Crap Cleaner is a freeware system optimization and privacy tool
EzPcFix 1.0.0.16
Helpful tool when trying to remove viruses, spyware, and malware
Content Advisor Password Remover 1.0
It Removes Content Advisor Password from Internet Explorer
Spybot - Search & Destroy 1.4 (0410)
Application to scan for spyware, adware, hijackers and other malicious software.
SpywareBlaster 3.5.1 (0410)
Prevent the installation of spyware and other potentially unwanted software.
Ad-Aware SE Personal 1.06 (0410)
find and remove spyware, adware, dialers etc. (a must have tool)
thanks very much for that. I didn't manage to repair the MBR but I managed to retrieve all my data off the drive and copy it to another. Deleted the main partition and managed to create a new partiton.
Morale of the story, don't defrag your hard drive when your power might go out.
