Memory Faults
The 8pin was there to be used. It provides extra power to the CPU. It won't burn anything out. I'm using it on my mobo with a 125w phenom ii so you should be ok.
But if you hadn't had that plugged in before your system messed up then that isn't the issue.
tbh i plugged this in to see if it works and it booted up normally. i then reseated the cpu (obviously after powering off) and thats when the problems started...
What psu do u have?
It may have been the adapter as it's drawing more power from a single 12v.
My psu had a 8pin cable with it. It could be that the 12v 4 pin has burned ou or something.
That psu should be fine as it's a strong and efficient psu. It shouldn't really have done that. But if that's a new thing you done before the problems. Then I would point it to that.
Our PSU has the proper 8 pin connector for the 8 pin socket on the motherboard. It's actually a 4+4 connector for use with older MOBOs requiring a 4 pin connector. Make sure you have this connector in the socket on the board.
yup mate thats exactly the cable im using, but the orientation or the way the pins are keyed dont match that on a UD5 so i can only use the 4pin. but if u look in the psu box there is an adapter so i can manipulate the orientation of the pins to match the other 4 on the mobo, hope that made sense??
hmm ok i will have to try this when i get my MoBo replaced (hopefully). but i am sure i tried it and am sure 4 pins weren't going in, as u mentioned its a 4+4 pin connecter. 4 pins i can easily fit in no problem but the other 4 pins just dont go in. the pin shapes are either square or rounded right?? well the other 4pin connecter all the pins are rounded. which dont let them go into the square shaped connections on the mobo (if that makes sense). what MoBo are u using?
TRUST ME;)
The shapes of the pins do not matter. We designed it to be universal so the MOBO does not matter. It will fit.
hey guys update on the MoBo...
have had a replacement issued, fixed it today and i am using it as i type, yaay! according to the RMA (excellent service may i add!), the problem was in the cpu socket and some other issues connected to the cpu on the MoBo that must have been damaged before I got it because it laid deep in the MoBo. anyways, it is running well and my initial problem of the RAM (6gb installed but only using 4gb) has been resolved also! yay
p.s. Yellowbeard you was right i was rong, the shapes of the pin do not matter the ATX 4+4 pin connecters do connect :)
It wouldn't turn on...
btw manisinghb congrats on getting it all fixed.
cheerz mate have had a couple issues in this build but considering it was my very first every build and i took the bold step of watercooling and overclocking (which i still need 2 do in due time with plenty research), i'd say i dont alright, thats y i called this project; mysterious IK (as u may kno in Panjabi language means One) lol :confused: :p
