Memory Mhz wrong??
just because the ram will do 2400Mhz, and your board/CPU will support 2400Mhz it dont mean you can run it at 2400Mhz.
start at 1600 and go up one speed raiting at a time untill you cant boot then drop down to the last stable setting
What motherboard / CPU do you have
the motherboard info says anything over 1600 is an OC(over clock) so not going to be guaranteed
Support for DDR3 3100(O.C.) / 3000(O.C.) / 2933(O.C.) / 2800(O.C.) / 2666(O.C.) / 2600(O.C.) / 2500(O.C.) / 2400(O.C.) / 2200(O.C.) / 2133(O.C.) / 2000(O.C.) / 1866(O.C.) / 1800(O.C.) / 1600 / 1333 MHz memory modules
try some of the lower speed 2200 2133 2000 1866 1800 and see how you get on
It boots not stable though its iffy on if it wants to make desktop or not.
Voltage on anything over 1600Mhz is 1.692 is that right?
Are there two xmp profiles available?
I have Kingston 2400 ram and the second profile is 2133MHz.
set it as xmp and then manually lower the voltage it does the same with my ram shooting up really high but lowering down to 1.6v and it runs fine.
Set xmp
Memory timings on auto (if this is linked or unlinked that's your problem!)
CPU input voltage at 1.95v (make sure this is input or vccio not vcore!!!)
Sa at 1.15v
Io/a/d at 1.15v
Manually set dram voltage to 1.65v
If that's not stable then update bios, if still not stable then memory isn't fully compatible.
If it is stable start to wind down the sa and io voltages.
When I installed my new ram into my pc, it took me about 20 mins to find a stable oc that could support the 2400mhz. Got it though.
How I did it:
Set Ram to XMP profile, and start off at 1866mhz.
Overclock CPU to a known stable without any fiddling (in my case 4.4Ghz).
Then reboot, if it boots go back in and up the Memory speed one up.
Repeat until it no longer boots, reset bios, match the previous setting where it crashed and back the memory speed down one.
I eventully got it running at its 2400mhz... I wasn't supplying the full Voltage to it.
