- 10 Mar 2004
Sounds very like the HL2 problem I and a couple of others had, do you get looping sound with the lockups? I'm starting to think all these glitches are related to one cause, only under different manifestationas
Yes, I had the that before, with their stupid windows update program! Have used AFUDOS ever since.
Just thinking on my feet here, but is there an autosave function in Rise of Empires aswell? No idea why this would make a difference, but so far, it's the only thing that has appeared to have a direct effect on one of the problems -namely the one in Oblivion.
I suppose we could also try bumping the mem voltage upto 2.30 from the 2.20 default, don't think it would hurt.
Mem issues are usually isolated by memtest or Prime95 and they're completely stable for me, as I'm sure they'd be for you, but you never know which such demanding games that put extra pressure on the system, think I'm grasping at straws here though.
Mem remap is under the Advanced/Chipset menu, top of the list.
