Memory problem, please help!
17 Jun 2005
Hey all,
Ill get straight to the point, i have been running 2gb of ram in my computer for a while, i recently loaded up the system information on my computer and it says that only have 1.75gb of ram, but in CPUZ it says i have 2048mb. On the post boot screen it says i have 1.75gb. I have no idea why this has suddenly lost 250mb of ram.
If i take out 1 stick it says i have 1gb of ram, if i put the other stick in, it says i have 1gb, so they both seem to be ok on there own, its just wen i put them together.
Processor - AMD 3700
Memory - 2gb Patriot
Motherboard - DFI Lanparty SLi-D
Cheers guys
Have you updated your Bios?
Check your Bios settings, memory hole remapping etc from the user manual
You could reloading optimized defaults and then set up Bios again
Simon
