try this
Amd cards flickering fix. Navigate to %LOCALAPPDATA%4A GamesMetro LL and open user.cfg with text editor.
Locate line r_api 2 and change it to r_api 0 for DirectX 9 renderer.
Change user.cfg to read-only to prevent the game overwriting changes.
maybe till they fix it with new patch may work.
I don't have AMD cards, I use GTX670 SLI and the flickering isn't ingame shadows, it's constantly, even from the video the second the game starts up.
You mentioned OSD a few times.
Tried running without that? Or are you just referring to the OSD for checking SLI use?
I am, use it to monitor my cards.
try this,throw your Nvidia cards out of the nearest window and order a pair of amd cards![]()
9970 is fast approaching...
edit// I'll try with the second monitor unplugged. Report back soon guys.
