[TW]Fox said:Since about 3-4 issues ago the Focus RS has been upgraded to 4.5 stars.
why, has it been improved?
Firestar_3x said:Nor do i, went in several last weekend, look alright on the outside but the interior is some 80's throwback design finished off with metro clocks.....
metro clocks rule
Pug said:why, has it been improved?
ShakenNstirred said:0-60 just under 7s and there cheap
Just under 7 seconds 0-60? I don't mean to pick, but it's more like just around 8 seconds @ 135hp. While only 1 second, to get a 0-60 in around 6.8s you'd need to squeeze something like 175hp out of that dieselShakenNstirred said:i`d get a rover 200 sdi instead of the petrol MG
very very easy and cheap(£50) to up the power from 105 to 135bhp with 260nm of torque
you can embarrass so called better cars with it
rdfcpete said:TutGet out
*slaps* xcessive
Any serious suggestions?
In what way?
And yeah, I've considered the Zetec S.
My dads had three Fiestas as his ADI cars, and he's loved every single one. They're reliable as muck, and he could probably get me half decent deal on one as he's bought his last 5'ish cars from FordThey usually sort him a pleasant price...
Just the MG is so cheap, and attractive, and seems good performance?
Regards,
Pete.
i was basing that on a guy on a rover forumPMKeates said:Just under 7 seconds 0-60? I don't mean to pick, but it's more like just around 8 seconds @ 135hp. While only 1 second, to get a 0-60 in around 6.8s you'd need to squeeze something like 175hp out of that diesel![]()
ShakenNstirred said:he says "its very good. mine does 0-60 in less than 7 secons
xcessive said:...however, finding an un-chavved up example is quite hard. I've noticed you are the same age as me (18) and when getting insurance quotes on a VTR i noticed it was more expensive than insuring a Zetec S. It's because of the chav image it has...
...Pug said:and completely standard(ish)
ShakenNstirred said:its more about the torque than the power to pull you to 60
rdfcpete said:Ha... What you done to it you cheeky thing?![]()
