with respect to the owner i was surprised to see the 2400G score damn near as high as a Ryzen 3000 series, the former is an older Zen+ architecture, a cut down one at that
Yeah the 2000 Series thing threw me2400G is actually a 14nm Zen 1, same as a 1600it does makes my Zen+ TR look bad but like you say the benefits of the newer ones are more than IPC, they hold higher clocks, more often and on more cores plus more cache etc. so in reality perform better than that benchmark would suggest, I would imagine bandwidth bares no relevance here, just latency as my apu and tr run same speed memory bar some minor timing differences and one has double bandwidth.
The 3200G posted above is the cutdown 12nm zen+ which appears to be quite strong.
I think the timings on the later crucial ram suit ryzen more vs my old old gskill ram on my 2400 vs 2920 and are probably what limits the TR in this bench, but it is fair to say my jump from zen1 to zen+ felt weak apart from running marginally better clockspeeds on the whole without the need for an overclock as boost is better on zen+ vs zen.
If I remember right the APUs are also weird because of how they're not welded together like the 6 and 8 cores, so they have a performance advantage (in some scenarios) similar to how the Ryzen 3300X is faster than it should be compared to the 3100.Yeah the 2000 Series thing threw meAPU's are a generation behind, the next generation are names Ryzen 4000 G and H ecte.... but they are Zen 2 (Ryzen 3000) damn it AMD.... unify your naming.
he was after 4Ghz clocks for comparison
Did you read the OP? Lol.3900 (non x) @4.3ghz
single 530
multi 8530
In that case here is mine, doing that it would be over 495 putting humbug's 3600 to shameI have but I'm too lazy to change the clocks, it's still a good reference point and you can always just divide by 43 and multiply by 40.
It does make sense, think his memory was clocked low. My score went up by 200ish by going from 3200 to 3600 on ramIn that case here is mine, doing that it would be over 495 putting humbug's 3600 to shame
sshhh FFS Humbug, don't give AMD ideas...Go away with your 3600 'super'![]()
