- 21 Oct 2011
- ST4
It wasn't built by Chinese sub-contractors by any chance was it?
Escobar TowersMore than likely Columbian in 80's Miami.
Escobar Towers
My guess... Corroded rebar from salt water leading to deterioration of concrete frame, no maintenance or inspections, or possibly recommendations ignored.
I've inspected first hand building along the south coast and seen what alt water does to older rc frames. So much spalling and breakout. It can be fixed though if caught early.
interesting point, that is the side of the building facing the ocean. Although reports say there were no internal signs of issues, like cracks etc. but then again how many times do you see/hear reports like this by owners etc to avoid any liability.
That was the incident that led to the banning of high alumina cement for fast high strength gain in some types of construction, consideration of progressive collapse criteria in buildings and methods of construction for precast system built structures. An important collapse study.I'm reminded of a partial building collapse in England a while ago. Part of a block of flats collapsed completely and the rest was untouched. There were serious flaws in the building but no external sign of them. I don't remember the name, so I'll look it up...Ronan Point. https://en.wikipedia.org/wiki/Ronan_Point
Failure on one floor, the floors above are deprived of necessary support and drop down, the sudden extreme load collapses the floor below the initial failure, drop, collapse, drop, collapse...the whole lot's gone in seconds. Horrifying and leaves the rest of the building standing. Also explains the reports of "sounded like an explosion" - the upper floors hitting the lower floors would make a noise so loud many people who heard it would think of an explosion.
Horrible.
Even more horrible is the fact that it was reported to be sinking for ages![]()
A study from researchers at Florida International University published last year found that the building had been sinking at a rate of two millimetres per year in the 1990s, which may have affected the building structurally.
But the author has cautioned that the study was just a snapshot in time. The building was constructed on reclaimed wetland, which experts say is always of concern as the land underneath can compact over time, leading to shifts.
On the sinking, the author of the study, Prof Shimon Wdowinski, told the Miami Herald newspaper: "We've seen much higher than that, but it stood out because most of the area was stable and showed no subsidence."
Link? Not seen that yet.Horrible.
Why was nothing done before this? Were the residents tenants? Owner occupiers? Why didn't the local authority force the works to take place?
It "sounded like an explosion" because it was an explosion. To be more precise, the initial cause of the Ronan Point collapse was a gas explosion in a flat on the 18th floor. Apart from a complete change in the way that that high rise buildings were built in the UK, Ronan Point had a major influence on Gas Regulation in the UK as well.
It wasn't until after Ronan Point and the following enquiry that "Corgi" was formed to oversee all Gas Regulation in the UK. Up to that point Gas installation used to be a "suck it and see" job that had no formal regulation at all.
