Micro ATX Advice
19 May 2004
Horsham, West Sussex
Hi,
I have a Home Theatre PC with the following
Gigabyte Z97M-DS3H (Micro ATX)
Intel i5-4690K
16GB DDR3
It is in a Silverstone GD04 so I am limited to micro ATX boards
This has latest Windows 10 but I can't take it to Windows 11 because it does not have built-in TPM or a TPM header
One option is to just leave it, accept that it is stuck on Windows 11.
But I also have the following spare components sat on the shelf
Intel i5-9600K
16GB DDR4
And am thinking that I could pick up a second-hand micro ATX motherboard.
Sounds simple but when I search on auction sites, I am overwhelmed, I need it to support the 9600K and TPM 2.0 (ideally built-in).
Can anyone recommend some suitable motherboards to look for?
It is an option, and something I might do. But one question about installing like this, what happens about updates - once it is loaded does Microsoft overlook that the system is non-compliant and allows windows update to work. Or would I need to do manual workaround with every update?
Plus, I have the components sitting around and it would be a shame not to use them.
regular windows update will work fine, the only "issue" you'll encounter will be when the major updates arrive (eg, 25H2 etc)
i'm not 100%, but from what i gather, to install these major updates, you'd need to do a full reinstall, ironically using rufus again :cry:
each major update is supported for 2 years, so plan to reinstall every couple of years
Yes most motherboards dont come with
The actual tpm module
Even if the socket is there to take one
Can't say i have ever had a board where you
Actually get the module
Not sure about that. On my main PC I was able to just turn on TPM and install Windows 11. Same with my son’s PC. Neither needed a TPM module to be fitted.
Yeah you can turn on the cpu tpm
Called ftpm on amd
And ptt on intel if I remember correctly
That's why people dont go buy tpm modules
To put in the tpm header if the motherboard has one
firmware TPM has been around since Intel 7th gen and AMD Ryzen 2000 series, hence no need for a separate TPM module
(but that being said, win 11 isn't compatible with Intel 7th gen...only 8th gen upwards)
All 8th/9th gen CPUs support a firmware TPM 2.0 via PPT, BUT you may need a BIOS update to expose those options, so I'd suggest checking the BIOS update list for Windows 11. In some cases, the Windows 11 compatible BIOS does not add any options, it just changes the defaults to make the install easier.
The following motherboards support 9th gen with a BIOS update:
H310, B360, Z370.
With no BIOS update ("out of the box"):
B365, Z390.
Technically, 6th/7th gen boards (100/200 series) can be modded to support 8th/9th gen CPUs.
From what I'm aware (with the systems I have): you receive security updates like normal. Feature updates (e.g. 25H2) need to be done manually, but if the update is only an enablement package (like 25H2 is) then I've just downloaded the installer via Microsoft and it flipped the switch.
H310, B360, Z370.
B365, Z390.
Thanks, that is really helpful. So with the i5-9600K I should be fine because TPM is supported by the CPU.
Yeah, but like I said, do check the BIOS updates for your chosen board. If there's a BIOS update mentioning Windows 11 then you should be good. If there's no mention of it, then I'd look in the manual (or BIOS manual, if there is one).
Question about BIOS updates.
If a board needs a BIOS update to support a 9th Gen CPU, does that mean that I would need an 8th Gen CPU in order to run the board to be able to apply the BIOS update?
Seems crazy, but I’ve read some posts suggesting that this would be necessary.
I'd expect the majority to have a compatible BIOS at this point, but yes, that's a possible outcome if the board has an early BIOS.
I don't think so. Remember that the new BIOS still has to support the old CPUs.
