Micro SD cards class 10 ?
Caporegime
8 Sep 2005
Norrbotten, Sweden.
I know very little about this except what ive read on Wiki.
Ive bought a 16gb one and its max transfer is 3,8MB a second... 22 minutes to copy 4gb to it ..
I thought these things, class 10, had a transfer rate of 10MB (over a USB cable)
Have i totally misunderstood this?
Yeah its trivial just annoyingly slow.
how are you connecting it to the computer?
i find that if i do it through my phone to the SD card, it is MUCH slower than a usb adapter
its in the device.
ill try it in an adapter thx.
Also I re-read what i wrote and ive been dumb :) read speed not write speed... still its slow :(
Ignore the classes on memory cards as it's not governed by any authority so companies can put whatever class they like on the label. You just have to look at the read/write speeds and see if they are fast enough.
The speed class is the minimum write speed as defined by the SD Association. if a card can't support it's rated speed it should be returned as faulty.
https://www.sdcard.org/developers/overview/speed_class/
One would assume the device doesnt have the CPU power to transfer that quickly. Or at least, not the power where it counts, it being more specialised to its specific role.
