**Middle Earth :Shadow of Mordor Bench Thread**
The menus have changed a little since this thread was made are you ment to run FXAA ?
just did a run 1440p
3930k @ 5ghz
Titan X 1509/8000
3930k @ 5ghz
Titan X 1509/8000
Whatever Ultra Preset grants in terms of AA. Your score is very low compared to mine and I'm running a stock 3930K and lower OC on the TX.
Is this 347.88 or 350.05 drivers ?
Managed a 1920x1080 a bit silly that I had to change my desktop res to get it to 1080 as I only had the choices of 70%-80% of 1440p :confused:
Couldn't take a screenshot, so took a photo instead.
i7 4790k @ 4.0Ghz
2x 980's 1367/7010mhz (boost clocks)
347.88
1080P
Average FPS: 131.62
Max FPS: 221.67
Min FPS: 49.90
5960X @4.8Ghz
4x Fury X @1100/500Mhz
15.7
5960X @4.9Ghz
15.7
New score. Btw, this is using higher settings than Greg has listed in the OP. :)
Settings used.
Greg are you still updating this thread? Any chance we can hand it over to Kaap because the image in the OP is not using the highest settings?
