Minesweeper King?!!
normanthefarmer said:
how you post a screenie and i show
open the scores page, and then press the print screen key on your keyboard. usually next to scroll lock and may say prnt scn. then paste into paint, save as jpeg and upload to free site such as uploadit.org
Clerkin said:
apparently so. read the whole thread tho.
dont think anyone would be that sad. and if they are i feel bad for their families
Actually I was thinking of another way, but you need a Pre-XP version.
Anybody else play gnomines?
ill put up a screeny later if you guys dont believe me, but i have done:
Beg: 6
Med: 36
Diff: 112
been trying for ages on 24x30 with 200 mines (done it with 190 mines), really difficult as so many times the end is just guessing.
I have had 4 seconds once. That was about 2 years ago. Basically I got an "8" and the other two were easy.
Beginner - 5 seconds (bit of a fluke)
Intermediate - not a clue, don't play this level much
Expert - 105 seconds
I used to play minesweeper waaaay too much, I've actually deleted the exe file cos I never get any work done otherwise! Btw, did anyone know that there's actually a cheat for minesweeper? I can't remember exactly, but if u push a combination on keys, a single pixel in the corner of the screen changes black or white depending on whether the mouse is over a mine or not. Pretty useless at getting a high score mind unless you're stuck right at the end!
I beat it on ultra hard before XP had even finished installing. I would've got a screenie but PRT SCRN doesn't work in the BIOS.
