Mini/micro LED QHD monitors
Doom is the fastest pace FPS I've played, and I didn't see ghosting on the old Samsung VA. Also the drop off issue with VA probably only when your head is on the left of the screen say 1" from the bezel and you look to the far right, then notice drop off. But with head in the middle it's fine.
More even black levels with VA...so IPS glow is pretty distracting.
that's mine
That's good to know.
I was actually swaying between the KTC and AOC agon pro ag274qzm.
My main monitor is always directly in front of me now, no odd sitting compared to when I got my IPS screen.
If/when I make the purchase, I'll likely make my LG my secondary monitor and remove my 1080p 75hz current monitor.
I played Doom Eternal as fast as I could and couldn't see smearing on the old Samsung VA, generally it's the slow panning which showed up the worst, and even then it's only specific things, like Tomb Raider in a corridor, side scrolling. And in RDR, at night side scrolling with the mountains
Unless I have a save game of the same area, it's difficult to come across it.
Love the idea of you shotgunning cans of monster in order to play a game as fast as possible to spot smearing.
Like I said, it’s very person dependent. Some people don’t notice VRR flicker, some people don’t notice tearing.
I had a 25G3ZM 1080p 240hz VA monitor for a short period whilst I worked away and whilst I actually found the monitor to be the best I’ve used in terms of how nice it felt on my eyes, the black smearing and scan lines were visible and noticeable (to me).
Can see it with the UFO test site however that probably is worst case scenario .
I remember trying the UFO test site on a MSI? IPS monitor in a high street retailer it did appear to have very little trailing .
New one has about twice as good as near black ghosting ?
Last I heard microLED consumer monitor tech was years away.
Probably 2030+
Currently no one is working on them, they are still trying to make smaller MicroLED TV's before they can even think about monitors
With MicroLED, the technology curve is like the opposite of old TV tech, where its easier to make very large MicroLED screens that it is to make smaller ones, so they started out by building 200 inch MicroLED screens and every year they are able to make it a bit smaller and smaller
Cost is still very prohibitive; the main issue is that you have millions of LED's on the screen and Murphy's law quickly takes over and thousands and thousands of those LED's are DOA and don't turn on, then the panel goes back into the factory and a machine has to replace the dead LED's one by one, they don't just throw the panel away they keep replacing LED's until they have 8 million that work. So its a very weird production line and every MicroLED is basically getting custom made due to how many attempts is required to get working LED's and because MicroLED panels for now are basically custom made, the cost is insane
@michty_me well if you do change your mind, @MartinPrince came to calibrate my my Xiaomi and apparently it's one of the best IPS panels he's done.
Once calibrated: 99.9 srgb, 90.6% Adobe, 98% dci-p3
Max delta-e was something small like 1.16 with an average of 0.2 or something like that.
That is pretty good! Impressive!
The new models appear to all be 5k/1440p dual resolution so will be coming in at a hefty price.
My main concern with 5k/1440p dual is the 5k not playing nice with the PS5 Pro but otherwise they do look really nice.
Looks like LG and MSI are releasing Mini-LED models - and Asus have a model that's going to be slightly cheaper but without the mini-LED backlight.
I didn't actually think of the PS5 Pro and compatibility but we shall see soon enough I would imagine.
After reading reviews of the monitors discussed earlier in the thread, Support is essentially non-existent so I would prefer to go with a more well known brand and hopefully better support for issues down the line.
Some of the articles I read on the new items from CES seem to suggest they will mostly all be using the same panel for the mini LED which appears to ring true with the specs going around.
I imagine at some point Sony would release an update to support 5k res (considering the PS5 'supports' 8k) - but if it's anything like 1440p it'll end up taking years. It took Sony so insanely long to support 1440p as a 'native' resolution for the console to output to.
Maybe by the time they do support it, Costs of these monitors will drop!
@Alexrose1uk Has given me a nudge. The Xiaomi can be had for £180 currently so I think I shall give it a whirl.
Yes indeed. I have bought a second one to replace my old AOC. MiniLEDs are also significantly more efficient than edge lit screens too. I save about 50w per hour per monitor.
The new monitor also comes with firmware 1.0.0.9 so all the red tint issues have been completely solved.
If you want my calibrated settings and icc profile let me know and I'll fire it across.
Now ordered. If you could, That would be great and hugely appreciated.
I wonder how it will look compared to my LG 27GL850.
I did read in the comments, All monitors ship with 1.0.0.9 firmware so that is ideal.
Damn I'm a little jealous, I'm still on older firmware, although my one generally plays nice, but even getting it replaced at the time, I didnt get newer firmware haha
Does it still lock down the menus on HDR in the newer firmware @tamzzy, or have any other noticeable improvements?
which firmware are you on? my first monitor is 1.0.0.7 and the red tint issue is literally a non-issue with the correct settings applied to bypass the bug
I am on 1.0.0.7 too, as with you, red tint generally isnt too much of an issue for me. Would be very interested to see if you could spot any differences when your 1.0.0.9 one arrives though :)
Honestly - USB port for firmware updates (and make them available), don't lock the menus in HDR mode, no red tint, no occasional too dark bug...it'd be a perfect monitor for the money lol
