Mirrors edge physx vid
the point is, physx does nothing at all any other physx engine can't do, it just does it, more accurately and realistically.... supposedly. because the coding is just real phsyics rather than estimation thats it, you still have to design realistic effects.
The problem here is its impossible, I mean inarguably and literally impossible to see the difference between realistic, and estimated physics if they are both implemented well.
The gust of wind that blows up litter on the roof when the helicopter is close, its default stuff, estimated or scripted physics can create a completely 100% identical scene at the fraction of the processing cost in software and you could simply not tell it wasn't real.
We've already seen, i think in one or both graw's, where the physx acceleration added more particles seen when explosions happen, however, they were badly designed and frankly didn't look realistic, also it was mostly the same every time.
Whats the conclusion, bad coding = poor looking physics no matter if its software or hardware, physx, havoc or any other engine.
Good coding = real feeling physics, no matter the engine used.
You should have stopped there.
I have yet to see a game implement realistic water and fluid animations.
e.g.
If i throw a grenade into a building and the building withstands the explosion. With the current generation of physics, the explosion goes off and the smoke goes through the still intact roof. If there was better particle physics, then the explosion would be forced through the windows/doors and the smoke would gather in the roof.
Or maybe there would be more extensive damage to the building.
With the current physics engines, this isnt being shown. I was hoping with the hardware accellerated physics, we would start to see this. Same with old software 3d vs hardware 3d.
Would have been nice to blow apart buildings in FPS games, rather than having the indestructible props we have now. To me, this oppertunity has been wasted with hardware physics being a flop so far.
This is what I was on about. While it's not a direct gameplay mechanic, it does make the world that bit more believable and so adds to the immersion and suspension of disbelief, and hence, improves the gameplay for people who find that kind of thing distracting when it doesn't act properly.
Obviously some people couldn't care less whether smoke behaves correctly, but everyone's different.
You can only do so much with "estimated physics" - people don't tend to notice the difference yet as they are used to the older very simplified physics - once games start using complex physics people will start to notice and appreciate the difference.
If we all followed drunkemaster's mentality we'd still be playing 2.5D games like wolfie3D.
In that mirror's edge video they made much better use of the physics capabilities of almost anything I've seen so far - and while the useage was for the most part incidental it was far better than the token useage typical upto this point and a long way down the road to much more immersive environments.
I agree that design is the important factor - but I also think physx is a good answer to the need for reasonable physics in games - it provides an easy entry point for the developer, it runs very well in software mode (particle and plank physics, etc. run with very high performance) and can fairly easily be ported to other hardware solutions. AMD need to swallow their pride and get on the bandwagon for the greater good and nVidia need to lighten up a bit.
Its perfectly easy to do non-scripted debris effects throughout a city using entity zoning, physics particles and forcefield physic effects.
Don't get it! What are multicore CPUs for then?
Surely on a Quad core processor, one or two cores could be used for the sort of nonsense this PhysX is rendering?
A GPU or PPU is much, much faster at the type of code required for gaming physics than even the most powerful Intel/AMD CPU.
The stuff which is going into games ATM should have no problem on 2 cores of a Quad.
Crysis psychics is meant to be quite good.
I remember a game could Black on the PS2/XBOX that had plenty of particles like i see in Mirrors Edge.
Any i will be getting the game,
The game is based on free running aka parkour. While the game itself doesn't look that great - I think its a step in the right direction albeit a clumsy one.
A good multi core CPU can easily handle 200-300+ primitive physics objects running simple plank physics, etc. and 10,000 or so physics particles - but it just doesn't have enough mips to make up for the lack of parallel execution required to do complex fluid dynamics and cloth effects and so on... while a CPU can handle enough primitive objects for todays games it would be totally outclassed in environments which were built almost entirely from physics objects.
So if you were to match NVidia's PhysX engine again two cores running at 3.4ghz, you think NVidia would win?
This has NOTHING to do with realistic physics, this is ONLY down to game developers coding into their game that a grenade can destroy the building, and design a destroyable building. THink about it, if they want, they can make an awful looking building that when a grenade goes off inside it, it simply dissappears and smoke goes everywhere, or they can make a scripted destruction that looks fake, they can make realistic looking glass blowing out of windows and smoke coming out or they can make a fantastically realistic looking sequence of events when you throw a nade into a building. It doesn't matter how it looks, or how its done, the fact that something happens, however it happens, simply needs to be designed, thats it. It has, again, nothing to do with physx, nothing to do with realistic physics, its a design matter. If you make every single building destructable you actually start to LOSE gameplay.
Imagine a single, or even more so a multiplayer level where you destroy every last building. Multiplayer, it just means you can see everyone and its just stand and shoot each other, not much fun. Imagine a HL2 map where instead of being funneled through a map into scripted events, instead you blow up every building, run everywhere, the gameplay goes to crap. Theres a reason designers don't let every building everywhere be blown up. Not least because your massively increasing the time to get the game out. Every new building you make doesn't need outside texturing only, it now needs internals, volume, ability to move through it, ability to be destroyed, textures for how it looks destroyed aswell as in one piece, you need to design every last bit for when its destroyed, etc, etc.
We've seen buildings before, we've seen smoke come out of windows. Nothing I've ever seen anyone suggest we need in terms of realistic physics, have we not seen to some degree in games before, without physx, which is enough proof that physx is NOT required. Its time, design, and what you lose when a whole map is destructable.
Some of the most freeform games, Crysis, weren't nearly remotely as well recieved as a far more scripted, structured and less explorable game such as COD4. I found COD4 more fun, as did lots of people. While in COD4 you couldn't blow up stuff, and Crysis, maybe offers some of the highest levels of physics and destruction in a game to date. Is physics really improving games, no, design, story and scripted events are still the driving force in ALL great games.
As you keep banging on about design is the key... but you seem to miss the point that you can also apply design to your physics implementation...
... assuming you go all out and make a map entirely from objects that are affected by physics you would weight them - so that i.e. doors would easily be knocked down or splintered by relatively small amounts of force whereas brick walls would take a lot more pounding and reinforced concrete almost indestructable...
Rubbish, basically, sorry to sound harsh but, its rubbish.
Please tell me what part of that demo needed super accurate physics, and what part couldn't be done by estimation or scripting. Because, falling, we've seen it in many games. A bit of cloth falling, seen it, a guy falling through plastic, not completely sure I've seen exactly that, but falling through doors that shatter, tables, boxes, etc, yes. Bits of litter blowing up randomly from wind, almost all games these days, jumping a little, jumping, seriously?
The other thing thats , uber freaking hilarious, is if you've played it on the console(played the demo, once, before being bored).
You make jumps, get absolutely NO WHERE NEAR the place you jumped to and magically appear and grab on to things. THe game itself, the jumps, they are so badly done in places that its a joke. Do i want realistic bits of litter to hit me from the wind(on a roof, where there is no litter no less :o , so magic litter), or do I want the physics, of the engine, to be good.
Physx, doesn't guarentee realistic looking physics, this is the problem, it guarentee's just this, realistic CALCULATIONS. The calculations can be used to very accurately depict a completely unrealistically designed jump. Here lies the problem the coding and design must be realistic, the calculation, accurate, or estimate, matters not. THe problem with physx is its ONLY the calculation, design is completely and utterly seperate and always, always will be.
IF you've played the demo, at the end when you jump to the helicopter, you jump very clearly "miss" the bit of the heli you would want to grab on to, appear to fall below the copter(way out of reach) then suddenly grab on. It feels, wrong, its unrealistic, the calculation doesn't change this.
Yeah as I said the game is crap it probably doesn't use physx for the character movement anyhow.
But it goes a long way towards getting proper physics into games rather than half baked scripted events or very simplified linear movement.
Once you've seen say a leaf blown in the wind, wrap itself around an object and still affected by the wind slide until it detaches again and carries on its merry way its a whole lot more immersive than a simple leaf particle that goes right through objects as if they aren't even there.
I have to agree with drunkenmaster.
Accuracy does not make anything good that is not already good.
32bit colour does not make every game have great looking gfx.
24bit 96Khz sound does not make every song a good one.
I could hardly compare a game with and without proper physics with color depth or audio quality...
If anything its like comparing synthesized tones from early games with the wave form audio used in todays titles.
They are all tools & its how well you use them what counts.
Having Physx equals nothing in its self if you don't know how to make good use of it & there is no game that does so thus far & what its doing is wasting resources with what effects they are displaying & if it was not for the big NV Physx splash screen i would not of even thought for a second that it was using Physx.
The comparison is using more resources than needed.
No point in making a 24bit 96KHz MP3 from a source of only 16bit 44.1KHz with no re sample/interpolation, it will not sound any better but will use more resources in 24bit accuracy for no noticeable gain.
