You want the removal of words specifically based on traits of identity, the same as with my other examples
I want words to apply by default to a person. It's only not done that way for sex and only in pronouns. Even when people devoted to sexism want to promote it in everything, they usually have to add it in. Do you use seperate words for any reference to people, depending on their "colour, height, weight, sex, race, age or any of that silliness"? You'd have to make almost all of them up if you do.
Imagine, for example, a group of 20 doctors. 10 are male. 10 are female. Every one of them has skin colour at various different points on the spectrum of human skin colour. Every one of them is a different height. Every one of them is a different weight. Every one of them is a different age. You assign them to 8 different "races". So what words do you use instead of "Doctor"? You could go with "Doctress" for the female ones (and presumably do, since you're advocating using different words for the same thing depending on sex), but what different words do you use instead of "Doctor" for all the rest of it?
Describing a person's appearance is a different thing. The words are relevant in that context.
you don't need to put "race" in scare quotes.
I put "race" in quotes because I think it's not a real thing. You may be scared of it, but I'm not. It's an idea I disagree with, but have to refer to. How would you indicate that in text?
OK, then - Explain why you would assign a human concept of gender or sex to a non-human, non-sentient, inanimate object that has neither reproductive organs, nor any perception of its own gender?
That's easy - I wouldn't.
