Hey guys, how's your network knowlage?
I need some help with this new computer i got from OcUK, it doesnt seem to have an IP address. I'm using a Belkin usb wireless device which works fine on my laptop.
My modem, network and card are working as intended (since i'm using it to post this
) and I have tried connecting directly to the modem and router with same results. All drivers are properly installed and working, the only problem is the network connections icon constantly trying to aquire connection.
Running Dos cmd. 'ipconfig' shows,
"IP Address....:0.0.0.0"
"Subnet Mask...:0.0.0.0"
Also in support tab within network status shows "Address type: Invalid Address" but has a physical address at least.
I have tried tinkering with Internet Protocal and Obtaining IP automaticly is a no go. I have also tried using a working static IP which almost connected...even thinks it is connected but isnt
(my setup is Cable modem - router - laptop/Mac OS is WinXP)
Little off topic Q: This is the 2nd fault I seem to have got with this new comp, not to mention the 10min startup. Do OcUK do refunds? the last repair they did took 4weeks and now with this new problem, i'm under pressure to get it done. Trying to stop my dad going to the trading standards office :S. (sorry about the mini rant but It had to be done
) and I have tried connecting directly to the modem and router with same results. All drivers are properly installed and working, the only problem is the network connections icon constantly trying to aquire connection.Running Dos cmd. 'ipconfig' shows,
). How can i configure the router? to me it is just the white box that relys info to the modem.
