ajgoodfellow said:The 40,000 mile service is a major service and this came to about £300.
The dealer service, at least in Broadstairs, was very good too. Check your brake pads, brake discs and wheel bearings as these often need doing at 40,000 miles too
Chris1712 said:Yeah the cambelt got done in 04, hasnt reached 40k yet.
Picking it up saturday, looking to get silver dash/speedo rings/spoiler off the bay for cheap before it comes.
leaskovski said:Hmm, how come you went to broadstairs for the service? I usually take my vaux down to Perrys outside Canterbury. Have you had some bad experiences with them? (My service is coming up)
Chris1712 said:![]()
Anyone got info on getting the screen/wheel controls to work with a pioneer hu......
[TW]Fox said:Although about as relevent to the discussion on whether buying a 1.8 SXi is a good ideas it would be had you walked into a 'BMW 316 compact, does it suck' thread with 'My M3 CSL is amazing'.
Chris1712 said:Insurance on an SRi would be a bit to steep for me, 18 0ncb!
Lord-Jaffa said:Hardly, considering the GSI was less than 3k more than the SXI new.btw you forgot to mention Mondeo in your post so i'll do it for you.
ajgoodfellow said:Nope - they're non-standard Vauxhall specific connectors
You'll need to get an adaptor from somewhere like Halfords
adwhitworth said:There are 3 ISO blocks on the Mk4. The usual 2 and one for the steering controls/cd changer/display. Although the main 2 are standard ISO connections, the 12v live and ignition powers are the wrong way round so you will either need an adaptor or to somehow swap them around.
