Why don't you spray paint it?
Because it would:
1 - Wear out
2 - Crack the second the tubing flexed
3 - Look totally naff
And void the warranty, which is why I'm doing it this way instead
Void the warranty on a £80 cooler haha, anyway ip hope all goes well
You're missing the point..
OP, i tried this before.
I bought the same ID tubing as the OD of the h100 tubing. I cut the tubing to length and the cut along the tube and fit it around the h100 tubes.
It looked horrible as it didnt fit properly. The cut tubing doesnt hug the h100 tubes.
If you were to get tubing and cut it into a spiral, wrap it around the h100 tubes, that may work better
Hmmm I see
I'm guessing it is all down to the tubing you buy possibly? The one in that youtube video looks pretty good, I've seen another pic also online that looked good. This one:
I'll have to see what it is like when it arrives, hopefully tomorrow
Also note, this and mine, is the H100i, not the H100, the tubing is slightly different, possibly easier to wrap something around?
the tubing in that picture looks great - i wonder how they did it
hopefully the tubing on the h100i is easier to go this with - keep us updated!
"Haha just wrapped the stock tubing with some white Primochill advance LRT tubing 1/2 ID x 3/4 OD."
No I'm not he's just playing it on the safe side however I personally wouldn't be that bothered since the failure rate on these clc are quite low.
OP please tell us exactly how you put the tubing around the stock tubing for future reference
