Not sure what you mean, most people on these forums at least seem to to think that these 720p low quality tests are a joke. Benchmarking at low resolutions with low details may "help judge CPU performance" but there are plenty of other benchmarks that do that. People are interesting in gaming benchmarks to see how the CPU performs in those games, at settings they are likely to use either now or in the future.
In which case there is no or very little difference between these CPU's, all these reviews, Toms Hardware, Tech Power Up ecte.... have the Ryzen CPU performing almost the same as the Intel CPU, aside from a couple of games where the game needs to understand Ryzen better, like Tomb Raider, even when you add all of the Avr FPS together the overall difference is still only 10%.
So I added Toms Hardware Ryzen review FPS together to come up with an overall score....
The scores are 1075 to the 7600K and 979 to the 1600X, If the 1600X is at 100% the 7600K is at 111%, so 11% to the 7600K.
Now because the 7600K is actually a little more expensive than the 1600X 'and the Ryzen 1600 is a lot cheaper while being the same CPU' Toms used the same priced i5 7500 as the "best CPU" in that category instead.
So adding up all the 7500 scores it comes to 929 points, now compare THAT to the 1600X which scored 979, yup the 1600X is 5% faster than the 7500, but because the 1600X is $30 more expensive the 7500 won "the best CPU"
Had it been up against the 7600K it would have lost as that is more expensive, had the i5 7500 been up against the 1600 (none X) the 7500 would have lost because the 1600 is the same price and faster, this is why Toms Hardware use these odd ball locked Intel CPU's and made a whole lot of "games only- no overclocking" disclaimers, because they are just cheap enough to make sense against the Ryzen chips,
if you ignore overclocking and everything outside gaming.
Its an obvious stitch-up.
Besides all of that the games which they used at the res and settings that they used there is actually no performance difference between them, take out Tomb Raider and there is literally nothing in it.
This is why when you test for CPU gaming performance you make the CPU work for it, if all the work is on the GPU then you would not see any difference in performance.
Aside from Tomb Raider there is no performance difference between these CPU's in Toms benchmarks.
If you make the CPU work for it, this happens.......
Why does that even matter ^^^^ ? because pepole upgrade thier GPU more than the CPU, GPU's get faster... so to keep up with future GPU performance CPU need to be faster.
Funny how the tables turn, on how to review CPU's the pro Intel argument is now what the pro AMD argument used to be!
Right now AMD are making better gaming CPU's than Intel, not just that, AMD are making better CPU's than Intel full stop.
http://www.tomshardware.co.uk/amd-ryzen-5-1500x-cpu,review-33880.html
http://www.tomshardware.co.uk/intel-core-i3-7350k,review-33797-2.html
